Activity Forums Adobe Encore DVD For all you with “Out of Memory” errors in Encore CS3
  • For all you with “Out of Memory” errors in Encore CS3
    Posted by Jon Gulbrandson on August 19, 2008 at 10:28 pm
    This problem has bugged me all day.
    I’m wrapping up this HUGE DVD project for a client, everything is going smoothly. I’ve already built this DVD and am now making some revisions.
    I click Build… it stalls.
    Try again.. same thing
    So, i narrow the problem down to the transcoding business… I transcode manually.
    ERROR! “OUT OF MEMORY! SAVE AND EXIT NOW”
    Ya.. google didn’t help, adobe didn’t help
    I set the 3Gb switch – nothing
    Checked my codecs/priority – nothing
    Re-imported the assets – nothing
    Cleared my Media thing in regedit – nothing
    you know what fixed it?
    I opened a new project, named it something dumb because it was temporary, imported the files I wanted to transcode. Transcoded them (which it performed amazingly well).. closed that project, opened up my problematic one… and now it works like a charm.
    ?????????????? I’ve had my share of retarded work-arounds with pinnacle/avid products, but Adobe.. come on…
    Kiran Babu replied 16 years, 8 months ago 5 Members · 15 Replies
  • 15 Replies
  • Jon Gulbrandson
    August 20, 2008 at 2:14 am
    Adobe Encore: Come for the blue-ray, stay for the crash
    This work-around is probably more of dumb luck…
    because Encore is doing it again.
    It refuses to build the DVD because it won’t transcode the AVI. So i manually transcode only to get “Out of Memory.”
    Doubt it…
    I’ve got over 2Tb HDD memory and 4Gb DDR2 RAM. I’m sporting a Intel Core2 Quad @ 2.8Ghz and Dual Nvidia 8800GT in SLI… I’ve got more memory than windows can shake a stick at.
    The worst thing is, this F’n thing has worked flawlessly until today. I haven’t installed anything wierd. I just reopened my project, replaced some clips, same codec / compression and everything…
    I’ve tried multiple work-arounds and fixes… It’s real hit or miss, sometimes it’ll work, other times it won’t load, other times it’ll run out of memory, other time’s it’ll crash, other times it gives me some BS operating sys. error…
    I’ve tried everything.
    If I load the exact same clips that are giving me problems into a NEW project, they transcode fine… This was my original workaround, and now it’s not working…
    Then it’ll work… then it won’t…
    I’m pulling my hair out here… any ideas?
  • James Moor
    August 21, 2008 at 12:46 am
    jon … don’t shoot yourself!!! There’s got to be a fix .. somewhere.
    I know this sounds nuts, but i’m including part of a chat session i had with Dell on a ‘General Error’ from Encore that (just as your problem) started out of the blue on an existing project for no apparent reason. I’ll tell you up front, it’s a painfull process but it may help. After disabling anti-virus and jumping through the standard hoops when you call tech-support, we got down to the below. And believe it or not, it worked. There was an applicaton that, when disabled, solved my problem. Good Luck!
    07/14/2008 04:26:29PM
    Agent : “We can try to create a clean start
    up environment using msconfig.”
    07/14/2008 04:26:52PM
    James Moor: “i’m open … how do we do that?”
    07/14/2008 04:27:09PM
    Agent : “Let’s got to Start -> Run and type
    msconfig and click Ok.”
    07/14/2008 04:27:31PM
    James Moor: “ok, i’m there”
    07/14/2008 04:27:40PM
    Agent : “Choose Selective Start Up.”
    07/14/2008 04:27:56PM
    James Moor: “ok”
    07/14/2008 04:28:30PM
    Agent : “Uncheck the box below that says
    “Load Startup Items.” Then go to the Services Tab.”
    07/14/2008 04:28:53PM
    James Moor: “ok … done”
    07/14/2008 04:29:13PM
    Agent : “Check the box in the lower left
    corner that says “Hide Microsoft Services.””
    07/14/2008 04:29:29PM
    James Moor: “ok”
    07/14/2008 04:29:40PM
    Agent : “Click disable all in the lower right.”
    07/14/2008 04:30:09PM
    James Moor: “ok … a bunch of check mark went away”
    07/14/2008 04:32:47PM
    Agent : “Once you choose OK, the system
    will need to restart to apply those changes. Once Windows comes
    back up, you’ll get a reminder box telling you that msconfig has
    been used to make changes. Check the box that says “do not
    remind me” and click ok to continue on to the desktop. I’d like you
    to then test the behavior of Encore to see if the issue is still
    present. If it is, I’d like you to go back to msconfig and choose
    normal start up to revert all the settings back. Then you’ll want to
    test with a different user account, just to see if the issue happens
    there as well. If you find that the msconfig changes helped, then
    you’ll want to head back to msconfig and systematically re-check to
    enable the services and start up items to find out which one caused
    the issue.
    07/14/2008 04:33:47PM
    James Moor: “ok, that should keep me busy for a while …. i hope
    … thanks.”
    07/14/2008 04:34:08PM
    Agent : “You’re welcome. You can email me
    at andrew_riggins@dell.com if you need to follow up on this.”
    07/14/2008 04:34:28PM
    James Moor: “will do .. thanks again. rebooting …”
  • Jon Gulbrandson
    August 26, 2008 at 8:23 pm
    WELL DONE SIR!!
    I followed your instructions, and I was able to complete my project and hand it to my client!
    Moral of the story = Encore does NOT play well w/ other programs/codecs/drivers
    I haven’t found the culprit yet, but I will… and when I do….
    haha
    anyways!
    Thanks! I haven’t had a single issue since i’ve done this
  • James Moor
    August 26, 2008 at 9:34 pm
    Great news Jon. You are the 3rd person who has been able to use this process to get Encore running on an existing project again. I’m glad it helped.
  • Eric Smith
    December 31, 2008 at 5:20 am
    After trying everything in this thread without success, I finally got to build my project by right-clicking on all transcoded files in the project and selecting “Revert to Orignal”. This reduced my project from 1.5GB to 400K. The project then re-transcoded everything and worked perfectly. It took all that time to re-transcode, but at least it worked.
  • Stephen Rutherford
    April 23, 2009 at 3:05 pm
    Trying all of these without success… any additional help here?
    Stephen Rutherford
    Graphics Producer: Gale Force Media, CanesVision & Wolfpack TV
    stephenr@carolinahurricanes.com
    CAROLINA HURRICANES: 2006 STANLEY CUP CHAMPIONS!
  • Jon Gulbrandson
    April 23, 2009 at 3:32 pm
    Wow, i posted this a while ago. I have been noticing some very quirky things with these Adobe Programs… Try right clicking on your C:/ drive (or whatever drive your OS is on) and clearing your TEMP files… haha.. this actually resolved a major problem w/ premiere one time…
    Basically, Do everything in your power to make it as though Adobe is the ONLY program on the computer. As if you built this computer, installed adobe, and nothing else… Do that, and it’ll work fine.
    Restart the computer, change all your Startup and nonessential program settings as mentioned earlier in this thread. Clean everything up, TEMP files, Recycle bin, old unused drivers, remove unused software, defrag, reboot again. If all else fails, completely remove anti-virus software.. I know that I ran into an issue with Kasperski interfering with Adobe one time.
    April 23, 2009 at 4:04 pm
    I actually have done this a couple of times (less uninstalling the Virus Scan…)
    Other issues I am having include the program hanging up trying to import something that just transcoded…
    I will once again dumb down everything else going on in the background as much as I can….
    Thanks for the prompt reply
    Stephen Rutherford
  • Jon Gulbrandson
    April 23, 2009 at 4:29 pm
    What are you transcoding / importing?
    April 23, 2009 at 4:48 pm
    Mostly quicktime .mov or windows .avi files. I am running CS3 on Windows XP Pro.
    Thanks, again!
    Stephen Rutherford
