Activity Forums VEGAS Pro Following a Roadmap
  • Following a Roadmap
    Posted by Allen Zagel on July 10, 2005 at 3:46 am
    Hi
    Some time ago there was a tutorial somewhere but I’ve lost it.
    I have a map I want to keyframe to follow a winding road in Vegas 5. I tried using pan and crop and got something less than useable. Too fast and jerky. I tried slowing it down using velocity envelop but to no avail.
    Can someone help me out please? Don’t think the brezier (sorry about spelling) would do it as I need to zoom in and follow the road. It’s not exactly a straight line either.
    Allen
    My web site features;
    China, China Railways and music.
    https://www.azagel.com
    Video site;
    https://www.asxmediaproductions.com
    Allen Zagel replied 21 years, 2 months ago 3 Members · 8 Replies
  • 8 Replies
  • Steve Edwards
    July 10, 2005 at 5:01 am
    I was trying to do that a couple of days ago. I didn’t really get the hang of the Beier Mask to work so, what I did was to take a map of the U.S. off of the internet, save it, then took the same picture to PhotoShop and drew a line from point A to point B, and saved it under a different name. Put the map without a line on the track, then take the map with a line and place it on the same track next to the first one. Now, overlap the two pictures a little till you see the crossfade. Now select transitions, and select the Linear Wipe transition. Now depending which direction you are going, determines which linear wipe you select. ( traveling east to west, select the “right to left hard edge” wipe ect.) Drag the transition into the crossfade area, and you have it.
  • Edward Troxel
    July 10, 2005 at 11:21 am
    If you don’t mind spending a little bit of money, Heroglyph has this funtionality built-in.
    Edward Troxel
    JETDV Scripts
  • Allen Zagel
    July 10, 2005 at 1:38 pm
    Ed, I already have Heroglyph. I got it when they had that special deal a year of so ago. I’ll have to look.
    Steve, It’s not a line I need to animate. It’s a small area of a larger map I need to follow. Now like a small pan/crop box following a line on a map.
    Allen
    Video site;
  • Allen Zagel
    July 10, 2005 at 2:16 pm
    I found what I was looking for…
    https://www.wideopenwest.com/~wvg/tutorial-4.htm
    ….but now I got to figure it out.
    Allen
    Video site;
  • Edward Troxel
    July 10, 2005 at 6:19 pm
    Definitely give it a check. It *may* be a new feature of version 2. I got to meet the creator of that program at NAB and it just took moments to create a path. He even added an airplane to the front of the line so the line appeared behind the airplane. Any shaped path could be created.
    Edward Troxel
    JETDV Scripts
  • Allen Zagel
    July 10, 2005 at 10:42 pm
    I think so Ed. I haven’t had Heroglyph installed in quite a while since I had hard drive and MoBo problems and finally bought 2 new computers. Now I’m getting everything installed again.
    However I did what I wanted. took me about 2 hours but I did it using pan/crop keyframes.
    You’ll see it as I’m sending you and Gary a DVD when it’s finished.
    Allen
    Video site;
  • Edward Troxel
    July 11, 2005 at 2:16 am
    I looked at the VCD you sent. It was interesting. Saw what appeared to be one rough edit (around 1:05??? – going from memory)
    Edward Troxel
    JETDV Scripts
  • Allen Zagel
    July 11, 2005 at 3:02 am
    Glad you liked it. It was just a fun thing. I sent to those who were involved. The friends and musicians. I’ll have to check that edit you mentioned.
    Allen
    Video site;
