Activity Forums Adobe After Effects Floating Text Trick
  • Floating Text Trick
    Posted by Dandan on July 27, 2006 at 4:49 am
    Don’t know what to call this effect…did a few searches and didn’t come up with anything…
    Check out this video:
    https://www.hunz.com.au/uploads/video/hunzgrandatlantic.mov
    A minute or so into the video, right after the “mug shot” sequence the words “I Blame You” are floating in mid air over a coffee table while a girl sorts out torn pieces of paper…
    What is the general approach to this? I’ve tried several things and so far havent had any luck…
    Nathaniel Westveer replied 17 years, 2 months ago 5 Members · 5 Replies
  • Ryan Hill
    July 27, 2006 at 2:04 pm
    The tricky part is matching the movement of the virtual camera with the movement of the real camera. Make note of the focal length of your camera when you shoot, and make your camera in AE match that. Track something in your footage as a reference to figure out the camera’s motion. In this clip, there is a checkerboard pattern on the floor in the back, which would be a pretty good thing to use, since you know they are all square.
  • Al
    July 27, 2006 at 2:10 pm
    the trick seems to be matching the camera move. whether they got the camera data and used that to match it; or did it by eye (my guess would be latter). really all the text is doing is rotating at the same speed as the camera, so it wouldn’t be difficult to dummy…
  • Steve Roberts
    July 27, 2006 at 2:11 pm
    Usually, the motion in the scene is first tracked using a matchmoving app such as Syntheyes or PFHoe. Then, the matchmoving app “solves” the scene, creating a moving 3D camera in a 3D space that matches the real camera’s motion. Then the data is exported to a 3D scene format such as Maya, Lightwave, or AE. That’s when you add the layers of text to the 3D scene, where the 3D camera matches the motion of the real camera. The original footage would be used as the background layer.
    AE cannot do the matchmoving — you need a matchmoving app to create the 3D camera. Or you could try to manually move AE’s camera to match the real camera, but that would drive you crazy.
  • Dandan
    July 27, 2006 at 8:57 pm
    OOoooOOooOOoo….More expensive software to drool over…woo
    Thanks for the direction, gents!
  • Nathaniel Westveer
    July 21, 2009 at 9:00 am
    haha yeah match moving by hand in after effects is insane …don’t do it if you don’t have too
    though I got really good at manual tracking
    -Typeunderground
