Activity › Forums › Apple Final Cut Pro Legacy › Flip Footage 180* / Apply Motion Attributes to Multiple Clips
Sam Eidson replied 16 years, 9 months ago 10 Members · 24 Replies
Rafael Amador
June 14, 2009 at 5:23 am[David Carroll] “All of your clips have just been rotated 180 degrees with no render time. Takes 2 second”
That you have RT playback doesn’t mean that there is no rendering.
Every effect applied, any change in the Motion tab means rendering, so a generation lost (unless you are in Uncompress).
The QT turn system imply no rendering. Just say to the player read in a different order.[David Carroll] “4. The effect is now shown on the EFFECTS tab 5. Select BOTH “
No. When you use a 35mm adapter you flip the picture only vertically.
rafael -
David Carroll
June 14, 2009 at 5:52 amre: [Rafael Amador] “No. When you use a 35mm adapter you flip the picture only vertically.”
Maybe your 35mm adapter flips differently than mine, but I can assure you that only flipping (FLOP) VERTICALLY will leave my actors on the wrong side of the screen. Therefore, BOTH is what it takes to restore the image.
David W. Carroll
Envision Designs -
Jeremy Garchow
June 14, 2009 at 4:41 pm[David Carroll] “Therefore, BOTH is what it takes to restore the image. “
Exactly, it’s upside down and backwards. The flop filter is the best, but there’s rendering involved. If you take it out to color, you will have to grade upside down as well.
