Activity › Forums › Apple Final Cut Pro Legacy › Flip Footage 180* / Apply Motion Attributes to Multiple Clips
Posted by Dustin Parsons on November 6, 2008 at 6:01 pmI have a lot of footage shot on the Panasonic HVX with the Redrock adapter that I need flipped 180* and I’d prefer not to use an Effect like Flop.
Is there a way to apply a 180* Rotation to the Motion attributes of all my clips at the same time before I drop them in the Timeline?
If not, does anyone have a method they’ve used before that doesn’t require rendering and will keep the footage upright when I send it to Color?
Thanks for your help
Mac Pro | Leopard 10.5.3
2.66GHz Dual-Core Intel Xeon | 4GB Ram
Final Cut Pro Studio 2 | Avid Media ComposerSam Eidson replied 16 years, 10 months ago 10 Members · 24 Replies -
Jeremy Garchow
November 6, 2008 at 6:09 pm[Dustin Parsons] “If not, does anyone have a method they’ve used before that doesn’t require rendering and will keep the footage upright when I send it to Color? “
Turn your monitor upside down.
Dustin Parsons
November 6, 2008 at 6:28 pmYeah, that seems to do the trick for the video but my mouse movements are backwards and all the text is upside-down. Maybe there’s another method?
Final Cut Pro Studio 2 | Avid Media Composer -
Arnie Schlissel
November 6, 2008 at 6:41 pm[Jeremy Garchow] “Turn your monitor upside down.”
Exactly what I was thinking!
Arnie
Post production is not an afterthought!
https://www.arniepix.com/ -
Jeremy Garchow
November 6, 2008 at 6:58 pm[Dustin Parsons] “Yeah, that seems to do the trick for the video but my mouse movements are backwards and all the text is upside-down. Maybe there’s another method?”
Your video monitor dude, not your computer monitor.
Dustin Parsons
November 6, 2008 at 6:59 pmI don’t have a video monitor…
Chris Poisson
November 6, 2008 at 9:25 pmWhat the heck is wrong with the flop filter?
Have a wonderful day.
Jeremy Garchow
November 6, 2008 at 9:27 pm[Chris Poisson] “What the heck is wrong with the flop filter?”
Lots of rendering
Dustin Parsons
November 6, 2008 at 9:35 pmCorrect me if I’m wrong, but if I use the Flop effect the clips will still be upside-down after sending the footage from FCP to Color?
Whereas if I was to rotate them 180* using the motion attributes they will not (this I know for sure).
Since nobody has answered my question
“Is there a way to apply a 180* Rotation to the Motion attributes of all my clips at the same time before I drop them in the Timeline?”
I’m assuming it can’t be done.
Jeremy Garchow
November 6, 2008 at 9:38 pm[Dustin Parsons] “”Is there a way to apply a 180* Rotation to the Motion attributes of all my clips at the same time before I drop them in the Timeline?”
I’m assuming it can’t be done.”
No, you can only copy/paste attributes in the timeline.
Jeremy
Keefe Kaupanger-swacker
November 6, 2008 at 10:08 pmSo quick steps that help me move faster.
1 – Double click a clip (master clip or timeline) to open it in the viewer.
2 – Goto the motion tab and set rotation to 180.
3 – Goto Menu – Effects:Make Favorite Motion (or ctrl^f)
4 – Goto Effects Window:Favorites Bin
5 – The Favorite you just created is in there titled “myclipname (Motion)”
6 – Rename to something like “Red Rock – 180 rotate”
7 – Goto Menu – Effects:Favorite Motion Effects to see what the quick-key is. Most recent favorite defaults to (ctrl^+shift↑+5)
8 – double click the clip that needs the rotation and push the quick-key for the new motion fav.With your bin opened in list form stretching from top to bottom of the screen you can power through 200 clips in less than 5 minutes. I know this isn’t the best but it is really pretty fast and it will be the correct orientation for color. If any of the Gurus know how to apply a filter or favorite to multiple master clips at once please step in here and share. I hope this helps at least decrease your time on this step.
Best,
Keefe Kaupanger-Swacker
keefe@bellsound.com
http://www.bellsound.com
