Activity Forums Creative Community Conversations Final Cut Update
  • Scott Witthaus
    November 15, 2018 at 8:30 pm
    I did. No problems yet. Just playing now.
    Scott Witthaus
    Visual Storyteller – FCPX, Premiere
    https://vimeo.com/channels/1322525
    Managing Partner, Low Country Creative LLC
    Professor, VCU Brandcenter
  • Steve Connor
    November 15, 2018 at 8:41 pm
    No sign of it here 🙁
  • Jeremy Garchow
    November 15, 2018 at 8:44 pm
    [Steve Connor] “No sign of it here :(“
    It just has to clear customs and you should be all set! 😉
  • Steve Connor
    November 15, 2018 at 8:45 pm
    [Jeremy Garchow] “It just has to clear customs and you should be all set! ;)”
    It’s probably on the red-eye, should be here by morning 🙂
  • Oliver Peters
    November 15, 2018 at 8:51 pm
    Since some of you were ragging on Resolve for playing “catch up”, let me point out that Workflow Extensions and Batch Share are merely features that “catch up” to similar features in Premiere Pro ☺
    – Oliver
    Oliver Peters – oliverpeters.com
  • Jeremy Garchow
    November 15, 2018 at 8:55 pm
    Wow. Actual visual timecode of all clips playing on the timeline.
    I missed this feature so much.
    It seems that FCPX caches all the Projects when you open the Library now, so it gets that long annoying process out of the way first, which is nice.
    OK, time to test frame.io!!!!
  • Steve Connor
    November 15, 2018 at 9:01 pm
    [Jeremy Garchow] “It seems that FCPX caches all the Projects when you open the Library now, so it gets that long annoying process out of the way first, which is nice.”
    So like every other NLE waveform re-drawing doesn’t slow the timeline down now?
  • Steve Connor
    [Oliver Peters] “Since some of you were ragging on Resolve for playing “catch up”, let me point out that Workflow Extensions and Batch Share are merely features that “catch up” to similar features in Premiere Pro ☺
    You beat me to it 🙂
  • Jeremy Garchow
    November 15, 2018 at 9:08 pm
    [Steve Connor] “So like every other NLE waveform re-drawing doesn’t slow the timeline down now?”
    Not quite sure yet, but there’s also been updates to MXF file reading which is great. I know you work with XAVC a lot (so do I) and it’s much better.
  • Steve Connor
    November 15, 2018 at 9:13 pm
    [Jeremy Garchow] “Not quite sure yet, but there’s also been updates to MXF file reading which is great. I know you work with XAVC a lot (so do I) and it’s much better.
    Well 10.44 just landed here (delays due to turbulence over the English Channel) and it’d definitely quicker with a 4K XAVC project that I currently have running. Fingers crossed, it would be a major bonus for me.
Page 2 of 4
