Activity › Forums › Creative Community Conversations › final cut pro x problem with templates, generators and titles
Diogo Mendes-pinto replied 12 years, 7 months ago 16 Members · 44 Replies
Jon Chappell
July 8, 2011 at 2:54 pmI’d be interested to know which file is causing this. The only file I have in that folder is located at Layouts/Modified/Default.moduleLayout. The other folders are all empty on my system.
My software:
FCS Maintenance Pack – Tools to keep Final Cut Studio running smoothly and fix problems when they arise
Pro Media Tools – Edit QuickTime files, detect gamma shifts, edit markers, watch renders and more
More tools… -
Bernard Ivol
July 8, 2011 at 4:04 pmWell done !
My folder user/library/application support/motion/presets/projects contained only one file.
I deleted it and opened FCP X. All blue icons disappeared. -
John Warner
July 8, 2011 at 4:18 pmBrilliant!!! I did this and FCP X seems to be working 100%! Thank you so much!
But, just wondering, Will trashing this file have any consequences with projects from my previous version of FCP?
Jeff Greenberg
July 8, 2011 at 4:26 pmMy guess (and it’s only a guess until I can verify it) that this was a preset from the prior version of motion that’s giving the current one a headache.
Best,
Jeff G
Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
You should follow me (filmgeek) on twitter. I promise to be nice.
New- my book (with Richard Harrington and Robbie Carman)- An Editor’s Guide to Adobe Premiere Pro
Compressor Essentials from Lynda.com
(older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
Contact me through my Website -
Jon Chappell
July 8, 2011 at 4:57 pmMotion 4 creates presets in the ~/Library/Application Support/Final Cut Studio/Motion folder. Could these presets have been created in an old standalone version of Motion before it became part of Final Cut Studio?
My software:
More tools… -
John Warner
July 8, 2011 at 8:08 pmI agree. i think that was my problem. I think it was preset from motion 3 that i had created. It is trashed now and all so far seems fine.
Mikey Bouchereau
July 9, 2011 at 1:10 amActually I am sure it was a motion 3 template. I created some some lower third templates in motion 4 on my mac pro, a while ago, for a client and his older Power Mac. To create the motion 3 templates I used a method that Mark Spenser pointed out on his Web site I just made sure that I did not use any motion 4 features.
HOW TO OPEN MOTION 4 PROJECTS IN MOTION 3
“Yes, you can open a Motion 4 project in Motion 3. It’s actually quite easy:1) Launch TextEdit
2) Choose File > Open, navigate to the Motion 4 project file, and open it.It opens in TextEdit and looks like this:
3) Change version=”4.0″ to version=”3.0″
4) SaveThat’s it! Your Motion 4 project will now open in Motion 3. Of course, any Motion 4 features, such as reflections, shadows, depth of field, or new behaviors won’t work, but all Motion 3 features should work fine. ”
I moved the old templates out only. And sure enough the blue issue is fix. I opened up the templates in motion 4 and resaved now I have them back as master templates for Final Cut Studio 3 and my Final Cut Pro X works perfectly.
Hopefully that info helps you out Jon. I love your tools!
Mikey B!
Check Out My Sky Replace Tutorial
Eric Simpson
July 12, 2011 at 7:25 pmDon’t know if this adds in any way to the discussion so far. I too have been having the problem of some generators and titles “turning blue”. Can’t quite bring myself to refer to the problem as the blue screen of death!
I should have started at the end of this thread and worked back but didn’t. Having tried removing the various plist and pref files to no avail I reached the advice to remove files from user/library/application support/motion/presets/projects. There was only one file in the folder and removing it also worked for me.
The file removed was Broadcast HD 1080 copy.preset. I am in the UK so NTSC presets are not appropriate for me. The Motion 5 Preferences do not include a 1080 25fps Preset and so to create a default preset Motion 5 creates a copy of a selected preset in the existing set of defaults.
Having solved the problem with your aid I decided to dice with the blue screen of death again and created a new 1080 25fps default in Motion 5. Sure enough the problem recurred, remove the motion preset and all is well.
I hope that this may give some clue as to what may be causing the problem.
Jay Ryde
July 17, 2011 at 8:28 pmYep I too had the exact same problem on my MacPro.. I too am in the UK so decided to create a 1080 25P preset. Removed it… So far, so good!!
Thank you.
