Activity › Forums › Creative Community Conversations › final cut pro x problem with templates, generators and titles
Diogo Mendes-pinto replied 12 years, 7 months ago 16 Members · 44 Replies
Jorgen Gustafson
September 11, 2011 at 9:30 pmIf I make new presets with Motion 5 the problem is there again – when i remove them it’s all ok again. So – it has nothing to do with old presets from Motion 3 or 4. And it’s not an issue just for presets with 25 fps – I’ve tryed with 30 fps presets and the blue death is there again. It’s a serious bug.
John Goldstein
February 4, 2012 at 4:08 pmHi Guys,
HELP! I am having the same problem (published template from Motion 5 to FCPX) and all it gives me is a blue screen for the generator and FCPX crashes out when I tried to play the new Generator.
I am new to FCPX and Motion 5. I was previously using Final Cut Express, so I have never used Motion 4 or previous versions.
I don’t even have the folders you listed. I have:
– Library/Application Support/Final Cut Pro
– Library/Application Support/Final Cut Express Support… so I don’t even have the Presets folder.
Within the Final Cut Pro folder, I have folders:
– Library
– Sample Media
– TemplatesWithin the Final Cut Express Support folder, I have folders:
– Custom Settings
– PluginsAny help would be greatly appreciated!
John -
Tom Gould
November 25, 2013 at 4:19 pmI have been having the same problem and have tried the solutions on this and threads on other blogs with no success. However, after some trial-and-error I finally came up with a solution. I logged in as a guest and copied the Motion Templates directory (with including all sub-folders), from the Movies directory onto an external thumb drive. i then logged into my main account and dragged this directory into the Movies directory of the main account. From the pop-up asking whether I wanted to overwrite the files, keep both or cancel, I chose overwrite. Once I opened Final Cut the contents of Titles, Generators and Themes had been re-populated and are all working again.
I hope this helps.
Diogo Mendes-pinto
February 12, 2014 at 11:46 amHi,
I have the same problem with the templates. Some of them don’t work.
I don’t have any of the files you guys mention before and Tom Gould’s solution dind’t work for me.
When I log in the user acount everything is fine but in the main acount they don’t work.
Anybody got any more ideias?I have FCPx 10.0.9 and Motion 5.0.7 on an 27′ iMac 3,4 GHz i7 32GB Ram and OS X 10.8.5
Thank you!!!
