Activity › Forums › Creative Community Conversations › Final Cut Pro X 10.0.3 Export Sound stops at 1:30 on a 2 minute piece
  • Final Cut Pro X 10.0.3 Export Sound stops at 1:30 on a 2 minute piece
    Posted by Stanley Leary on February 19, 2012 at 4:39 am
    I have cleared preferences, repaired permission and done restarts to clear the software.
    I have a 2 minute package with 2 cameras synced and music.
    Plays fine until you export. Tried every format and all the sound just stops at 1:30 on the 2:00 project. Video looks fine.
    Jerry Hofmann replied 13 years, 12 months ago 9 Members · 22 Replies
  • 22 Replies
  • Jerry Hofmann
    February 19, 2012 at 1:40 pm
    Tried exporting a self contained movie? It’s found through the export command in the Share menu? This might preserve the audio, then use that file to make your delivery compression.
    Post the format of the video and audio you’re working from too.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Stanley Leary
    February 19, 2012 at 1:55 pm
    I did do self contained export. I tried almost everyone with the same results.
    One movie is AVI and the other is Mov. I have a MP3 audio. Plays just fine in the program.
  • Jerry Hofmann
    February 19, 2012 at 2:30 pm
    Have you tried just exporting the audio only? If it works, you could import that file and replace the separate audio clips with it…?
    Only other thing I can think of is to transcode the MP3 files to aiffs then export it using those instead.
    Jerry
    Current DVD:
  • Jerry Hofmann
    February 19, 2012 at 2:46 pm
    Also!
    Make sure that the sequence is completely rendered too.
    Jerry
    Current DVD:
  • Stanley Leary
    February 19, 2012 at 3:01 pm
    I did try exporting audio only and the combing it, but the audio alone does the same thing.
  • Jacob Lanum
    February 19, 2012 at 3:47 pm
    Oh my god. I had this happen a few weeks ago. I could not find a reason for it or a fix. I had to to rebuild much of it in a timeline with tracks.
    Fcpx is pretty slick but he has some brain damage and forgets way to many things to be a useful tool
  • Jeremy Garchow
    February 19, 2012 at 3:52 pm
    Try deleting your render files?
  • Oliver Peters
    February 19, 2012 at 4:13 pm
    I had a similar issue on a project round-tripped in from Resolve. The fix was to copy & paste the clips to a new, empty project.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • Stanley Leary
    February 19, 2012 at 5:58 pm
    I just totally redid the project. By the way the audio is straight from itunes and not MP3.
    This time the audio craps out at the same point. However I am noticing it fading out this time.
    Output to mov with h.264 and a few other settings and all give the same results.
  • Steve Connor
    February 19, 2012 at 6:36 pm
    Have you tried another track just to confirm it’s the original track causing the problem?
    Also can you convert the track from iTunes to a 48K AIFF file to see if that works?
    Also is it track purchased on iTunes?
    Steve Connor
    “FCPX Agitator”
    Adrenalin Television
Page 1 of 3
