Activity › Forums › Creative Community Conversations › Final Cut Pro X 10.0.3 Export Sound stops at 1:30 on a 2 minute piece
  • Winston Hoy
    October 5, 2012 at 3:46 pm
    Having the same problem. I found this advice to work as well, but I’d also like to have this bug fixed, understand how to work around it.
    “I had a similar issue on a project round-tripped in from Resolve. The fix was to copy & paste the clips to a new, empty project.”
  • Jerry Hofmann
    October 6, 2012 at 2:09 am
    Sorry didn’t see your reply.
    You didn’t understand me. Take the audio files from iTunes, and rebuild them in compressor to an aif file. Then edit those aif’s into the sequence,replacing the old audio files.
    The audio file’s format is causing this problem I’ll bet, and you need to rebuild it so that when export happens, it doesn’t cut out.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Page 3 of 3
