Activity Forums AJA Video Systems Final Cut Pro and AJA Kona 3G Image output on monitor
  • Final Cut Pro and AJA Kona 3G Image output on monitor
    Posted by Dave Boampong on February 14, 2011 at 2:49 pm
    Hi Guys,
    I am getting this jagged edge look in Final Cut Pro 7 even before I add the Title to a time line. I am going through the Kona 3G to an LG 32PC5RA plasma TV through the supplied HDMI cable. Is there a way of getting rid of this stair stepping?
    Thanks a million in advance.
    Dave Boampong replied 15 years, 6 months ago 4 Members · 17 Replies
  • 17 Replies
  • Michael Kammes
    February 14, 2011 at 3:28 pm
    Lets start with the basics:
    What resolution & codec is your timeline?
    What are your output settings in FCP?
    What are your Kona3 Control panel settings? (Frame Buffer and Output)
    ~Michael
    .: michael kammes mpse
    .: senior applications editor . post workflow consultant
    .: audio specialist . act fcp . acsr
    .: michaelkammes.com
    .: twitter: @michaelkammes
    .: facebook: /mkammes
    Hear me pontificate: Speaking Schedule .
  • Dave Boampong
    February 14, 2011 at 3:51 pm
    Thanks for your prompt response. I will send this info immediately I get to the studio. Immediately.
    Dave
  • Dave Boampong
    February 14, 2011 at 3:58 pm
    Before I leave the Internet cafe for the Studio I will load this picture up as I don’t have adequate internet connection there in the studio. I can load up all other info from there though.
    This still is from the time line. I will post all details.
  • Gary Adcock
    February 14, 2011 at 4:11 pm
    Dave
    without knowing what you have it is hard to help.
    IF you are cutting SD footage and viewing on a native HD display there is a very good chance the monitor is causing the issue.
    IF you are cutting HD footage, you could have a down converted output that your monitor is up-converting
    turn off any settings in the monitor use the default or Standard settings.
    DO NOT EVER use any enhanced images settings on your post monitoring solution.
    gary adcock
    Studio37
    Post and Production Workflow Consultant
    Production and Post Stereographer
    Chicago, IL
    https://blogs.creativecow.net/24640
  • Dave Boampong
    February 14, 2011 at 4:27 pm
    Compressor: XDCam EX 1080p25
    Pixel: Aspect: Square
    Frame Size:1920 x 1080
    Field Dominance : None
    Editing Timebase: 25
    I shot the footage with the Sony EX3 and captured the clips into FCP 7 via the log and transfer plugin. I edited native and am using that in the easy setups to output through the HDMI, primary setting to the monitor. I will set the plasma TV to its default settings though I don’t think I have touched them.
    Thanks Guys.
  • Michael Kammes
    February 14, 2011 at 4:32 pm
    Getting there!
    Those are the FCP Sequence settings.
    What is the output set to via the Kona, and what are the Kona control panel settings?
    ~Michael
  • Dave Boampong
    February 14, 2011 at 6:34 pm
    Video Playback: AJA Kona 3G 1080i25 8 bit 1920 x 1080
    Audio : AJA Kona 3G
    Control Panel
    Inputs SDI 1: No Video
    Format
    Primary
    1080i25
    Secondary
    625i25
    Digital Out
    Primary 1080i25
    Analogue Out
    Primary 1080i25
    HDMI
    Primary 1080i25
    Protocol :Autodetect
    Color space Autodetect
    RGB range SMPTE
    Audio Ch. 8 Ch 1-8
    Default output
    Black
    Downstream keyer off
    Analogue black level 7.5ire
    Frame rates 23.98/29.97/59.94
    24/30/60
    25/50
    Geometries -unchecked
  • Dave Boampong
    February 14, 2011 at 7:43 pm
    I just checked and the the monitor is set to the default settings. I am still getting those jaggies. I am using the LG 32PC5RA TV.
    The only way the jaggies disappear is if I use the anti-aliasing filter TWICE and set to FULL (10)
  • Michael Kammes
    February 14, 2011 at 8:06 pm
    Well, I see a mismatch off the bat.
    Your Sequence is at 1080p25, your output is at 1080i. Rectify the output to match the sequence and see if that helps.
    ~Michael
  • Dave Boampong
    February 14, 2011 at 8:29 pm
    I just set the output to Aja kona 3G 1080 psf 8 bit 1920 x1080 but there was no change.
