Activity › Forums › AJA Video Systems › Final Cut Pro and AJA Kona 3G Image output on monitor
Dave Boampong replied 15 years, 6 months ago 4 Members · 17 Replies
Dave Boampong
February 15, 2011 at 7:17 amHi guys, I am not getting an Aja Kona 3G 1080p 25 setting in the video playback settings in Final cut. The closest I am getting is 1080psf25. I set the format in the Kona panel to 1080p25 and got the warning (P) formats are rare, you may want to progressive (sf). The jaggies remain.
Dave Boampong
February 15, 2011 at 7:26 amHi, the first picture is a Boris Title 3D graphic that I am playing out to the monitor from the viewer. I have not put it on the timeline.
The second picture is a close up of the edge of a client’s suit where his shirt and tie meet. This I am playing from the timeline.
I took these stills off the screen by holding a Fujifilm Finepix Z still camera close to areas that show the stair stepping. 🙂
Jeremy Garchow
February 15, 2011 at 1:48 pmIs your footage and timeline set to a field dom of none? Is this only when the timeline is paused? You can change the pause settings to full frame from single field in the AJA control panel.
Also, can you please explain what we are looking at there? It’s really hard to tell. You aren’t trying to use a 3d motion filter are you?
A bit more info would help.
Jeremy
Dave Boampong
February 15, 2011 at 3:12 pmYes the field dominance is set to NONE. This happens whether the playhead is both playing and paused. The pause settings in the AJA control panel are set to full frame. I changed the settings to single field but nothing changed. I have not applied any filters. Thanks for your responses guys.
I used a small digital camera to record what I see on the monitor and put it on YouTube 🙂
https://www.youtube.com/watch?v=Nj9c9TJw2j8
Dave Boampong
February 15, 2011 at 3:19 pm
