Activity Forums Apple Final Cut Pro Legacy final cut pro 5.1.2 won’t launch
  • final cut pro 5.1.2 won’t launch
    Posted by Camilla on December 1, 2006 at 3:46 am
    final cut pro 5.1.2 was working fine on my machine
    I moved all my media from my internal hard drive to an external drive
    everything appeared to be fine
    then I deleted all my media from my hard drive
    rebooted
    then final cut would start launch and basically abort w no message after going through part of the launch
    then I did a clean re install and update
    still won’t complete the launch
    any ideas?
    the only suggestion someone has made to me is to re-install yet again
    all suggestions appreciated
    Thanks!!
    Camilla
    Hhhhdfx replied 19 years, 10 months ago 5 Members · 18 Replies
  • 18 Replies
  • Jeremy Garchow
    December 1, 2006 at 4:35 am
    Have you tried launching fcp without launching that particular project?
  • Camilla
    December 1, 2006 at 5:46 am
    Yes I have tried launching from the icn on the dock, from the application in hte app folder, from different projects.. its all the same ;(
    thanks
    C
  • Jeremy Garchow
    December 1, 2006 at 5:49 am
    When you deleted your media, what else did you delete?
    Have you trashed your preferences?
  • Camilla
    December 1, 2006 at 5:55 am
    that is the million dollar question
    what did I trash unintentionally
    when I went to prepare to reinstall Final Cut (because it wasnt launching)
    I went first to look for the preferences in the library, to dump them
    and they were not there
    oddly now that I have reintsalled Final Cut there still is no file in prefrences
    The only wierd thing from around the tme I dumped the media files was that I was prompted to select the scratch disk.. it couldnt find something so I just indicated the scratch disk I wanted it to use
    and then it never worked again
    I have nver been able to or had the chance to reset the scratch disk again
    grazie
  • Jeremy Garchow
    December 1, 2006 at 6:01 am
    [Camilla] “and they were not there”
    User folder > library >preferences > final cut pro user data ?
    Sorry to be so rudimentary here, but I am just being thorough.
    Jeremy
  • Shane Ross
    December 1, 2006 at 6:02 am
    FCP Rescue anyone?
    This does it for you. Just click TRASH and it trashes your prefs…
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Camilla
    December 1, 2006 at 6:06 am
    Jeremy thanks for taking the time to walk me through this
    If I go to my internal hard drive library folder there is no file or folder refering to final cut at all.
    I was looking for something I thought would be called com.apple.finalcut.preferences
    or something like that.. no?
    C
  • Camilla
    December 1, 2006 at 6:09 am
    wait wait wait
    i just did a search and found it
    a folder in prefernces in the library called final cut pro user data
    there are also some funal cut Pro Cache files.. shall I delete all these things??
    i will wait for your advice
    thank you!!!!!
  • Jeremy Garchow
    December 1, 2006 at 6:12 am
    [Camilla] “I was looking for something I thought would be called com.apple.finalcut.preferences”
    Nope. Go to your Hard drive, then go to your user folder then the account folder (the one with the little house icon named whatever your computer is named) the go to library then find the final cut pro user data folder.
    Don’t go to the library folder at the root level of your hard drive.
    Make sense?
    Jeremy
  • Jeremy Garchow
    December 1, 2006 at 6:15 am
    Delete:
    Final Cut Pro 5.0 Prefs.fcset
    Final Cut Pro Obj Cache.fcmch
    Final Cut Pro Prof Cache.fcpch
    Relaunch
