Activity › Forums › Apple Final Cut Pro Legacy › final cut pro 5.1.2 won’t launch
Camilla
December 1, 2006 at 6:19 amgreat
2 files remainFinal Cut Pro 4.5 preferences .. I assume I should delete that? (ouch)
Final Cut Pro POA Cache (dated the same as Final Cut pro 4.5 file) delete also?what a good person you are!
Camilla
December 1, 2006 at 6:35 amok back in business
now returning to the other problems I created moving the media in the first place… lets hope I am not back here tomorrow asking why reconnect isnt working for me!not sure why you donate your time to do this but it is very appreciated!!!!
thanks again
Camilla -
Jeremy Garchow
December 1, 2006 at 6:39 am[Camilla] “not sure why you donate your time to do this but it is very appreciated!!!!”
It’s not a problem. I figure it’s good karma. If it’s not, I am in a whole heap of trouble. 😉
Glad you are up and running and if you can’t get anything reconnected, please write back. You will not be able to reconnect render files so plan on re-rendering everything and you might as well check the ‘ignore’ box on the render files (NOT the media files) when you first launch your project.
Jeremy
Camilla
December 1, 2006 at 7:21 amexcellent.. any articles you can point me to or
any advice you can give about how or what to delete on a regular basis to keep from loading up my drives with unnecessary stuff?good night!
Shane Ross
December 1, 2006 at 7:29 amDid I not mention FCP Rescue?
Click on this: FCP Rescue and download it.
Shane
Littlefrog Post
http://www.lfhd.net -
David Roth weiss
December 1, 2006 at 7:51 am[Camilla] “any advice you can give about how or what to delete on a regular basis to keep from loading up my drives with unnecessary stuff?”
Camilla,
500gb hard drives are $170 now. Get one.
DRW
Hhhhdfx
December 2, 2006 at 2:21 amThis might be obvious, but one thing that helps, esp. in HD is to maintain awareness of the space your render files are taking up. Just go Tools>Render Manager and take a look. Sometimes old ones get wierd corruption too. Their naming convention makes zero sense if you actually open the folders but you can play them.
