Activity Forums Apple Final Cut Pro Legacy Final Cut Pro 5.1.1, Panasonic Varicam, Panasonic 1200A deck and Audio Sync Issues
  • Final Cut Pro 5.1.1, Panasonic Varicam, Panasonic 1200A deck and Audio Sync Issues
    Posted by Cleditor on September 16, 2006 at 4:07 pm
    i have dvcpro hd footage from the varicam and am loading it via firewire into my fcp 5.1.1 system. when listening to the deck during capture everything is in sync. when playing back on my 23″ apple display, all audio is 9 frames later than picture. for now, i am sliding the audio forward 9 frames, but i’d rather fix it on capture. any thoughts?
    thanks,
    c
    Mark Maness replied 19 years, 11 months ago 5 Members · 12 Replies
  • 12 Replies
  • Mark Raudonis
    September 16, 2006 at 5:25 pm
    How are you monitoring audio? Firewire introduces a 5-8 frame delay relative to the audio coming out of the computer. In other words, if you’re monitoring “built in” audio from the computer, it will be 7 frames off from the picture going out to the NTSC monitor from the deck. The only way around this is to use a capture card like the AJA or Blackmagic. Firewire will always cause a delay.
    However…. the actual files ARE in sync. Check the waveforms against a slate.
    Mark
  • Shane Ross
    September 17, 2006 at 12:34 am
    God I hate being contrary, or the exception, but when I playback the footage on my canvas and have my mixer connected via the Built In audio port, there is no delay…0 frames. If my mixer is connected via firewire, 0 frame delay. if I monitor on my HD monitor thru my decklink HD card…0 frame delay.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Mark Raudonis
    September 17, 2006 at 2:54 pm
    Shane,
    It’s not the firewire audio (your mixer) that causes the delay, it’s an external firewire VIDEO box like the AJA i/o that is the culprit. Your Decklink card is internal, so it’s on the fast bus, hence no delay.
    mark
  • Cleditor
    September 17, 2006 at 3:01 pm
    thanks for all the input. i am monitoring the audio and video on my 23″ apple display. the deck is not even connected when i’m watching the playback of my captured clips. so, how could the firewire be the issue? unless, the delay is happening upon capture?
    c
    thanks,
    c
  • Kevin Monahan
    September 17, 2006 at 6:29 pm
    No FireWire, then it has to be your playback offset.
    System Settings > Playback Control > Frame Offset = 0
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
  • Shane Ross
    September 17, 2006 at 6:39 pm
    [Mark Raudonis] “It’s not the firewire audio (your mixer) that causes the delay, it’s an external firewire VIDEO box like the AJA i/o that is the culprit. Your Decklink card is internal, so it’s on the fast bus, hence no delay.”
    Ahhh…Thanks Mark. I will admit that I don’t know technical reason as to why things work certain ways, just that they work or don’t work. My mind is too much focused on the story to dig into the why.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Cleditor
    September 18, 2006 at 3:23 am
    the frame offset is set at 0. any other ideas?
    thanks,
    c
  • Mark Maness
    September 18, 2006 at 2:24 pm
    If that is the case and its still doing it…. Set your frame offset to 9. That is what the frame offset is for, you know.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
  • Cleditor
    September 18, 2006 at 5:03 pm
    wayne, i do know what the frame offset is for and i have already tried that. i have tried adjusting the audio/video settings >device control>playback offset, audio/video settings >device control>capture offset, and system settings >playback control>frame offset. so far none of this is working.
    thanks,
    c
  • Mark Maness
    September 18, 2006 at 6:40 pm
    Have you tried to monitor the audio from the deck?
    Wayne Carey
    Schazam Productions
