Activity Forums Apple Final Cut Pro Legacy Filters and Effects not working
  • Filters and Effects not working
    Posted by Jacqueline Bazinet on June 21, 2008 at 2:11 am
    I am running FCP 5.1.4 on a Intel MacBook 2GHz Core 2 Duo with 1 GB memory and OS 10.4.11. I’ve been an FCP user for 5+ years and this is the first time I’ve seen this particular problem.
    The effects and filters worked for a while after installing FCP, but then stopped taking “effect”. I can add effects to a clip, but they don’t do anything. Both video and audio filters and effects are not working.
    The transitions work by the way, no problem with any video or audio transitions.
    I trashed preferences, without any effect on the problem.
    I’ve been using this laptop as a back up mostly, so I am able to finish projects on my G4 tower, but I’ve gotten quite attached to my laptop…and this is really annoying. I’ve trolled the forums with no answers yet.
    I saw one other post on this subject with no answers.
    Jacquie Bazinet Tolson
    Thanks! Appreciate your help.
    Matt John replied 9 years ago 15 Members · 21 Replies
  • 21 Replies
  • Don Greening
    June 21, 2008 at 5:11 am
    You might end up having to re-install Final Cut Studio in order to get your effects back. If you do, then use this utility to un-install first:
    https://www.digitalrebellion.com/fcs_remover.htm
    But if you have more time to investigate why some of your effects have disappeared I would suspect that it’s a maintenance problem with your laptop. Over time and without periodic maintenance some files may become “orphaned” and big programs will lose the ability to find things like plugins, etc.
    Try using Disk Utility first and repair your startup drive’s permissions. Then use DiskWarrior to rebuild the directory on your startup drive. DiskWarrior is a great program that has righted a lot of wrongs with regard to reconnecting everything a program like FCP needs to function properly.
    https://www.alsoft.com/
    But if you’re in a hurry and don’t have access to DiskWarrior until Monday (when you rush out to buy it!!) then by all means re-install Final Cut Studio.
    – Don
  • Rafael Amador
    June 21, 2008 at 9:31 am
    I second Don’s suggestion. Run DiskWarrior or TechTools in a regular basis and avoid those situations.
    Is like the lubricant for the Mac OX engine.
    Rafael
    http://www.nagavideo.com
  • Jacqueline Bazinet
    June 22, 2008 at 5:02 am
    Thanks, I believe I repaired permissions already, but will do again, just in case I just *think* I repaired them. Not in too much of a hurry but would like to get this fixed soon! I love being able to rough edit anywhere, although I wish I would have splurged on the MacBook Pro…
    Will report what works.
    JBT
  • Rafael Amador
    June 22, 2008 at 11:26 am
    Hi Jacqueline,
    The maintenance that DiskWarrior or TechTools do, is something much deeper than just repair Permissions. They re-build the HDs directories.
    I run DW once every week or two weeks even if everything goes well. As soon as I run it, my external HDs speed up a 25 %.
    Rafael
  • Don Greening
    June 22, 2008 at 7:11 pm
    [Jacqueline Bazinet Tolson] “Will report what works.”
    Yes, please do. That way we’ll be more able to help the next person as well as yourself.
    – Don
  • Kate Perkins
    April 6, 2010 at 10:30 pm
    These suggestions are kind of extreme. The filters are just probably turned off in your preferences. Go to that sequence’s preferences (right click on the sequence in the Browser and select “Setting” from the pop-up menu.) Click on the “Render Control” tab. Make sure that the box next to “Filters” is checked under the “Render and Playback” section. You’ll probably have to render the entire timeline. I’m running 7 but I’m pretty sure this holds true for 5 as well.
    -Kate Perkins
  • Sean O’sullivan
    June 13, 2010 at 1:15 pm
    Picking up in support of Kate’s advice, this action did the trick for me…between projects lost my control over image and hunted all over for the switcher. One forgets things quite basic…thanks Kate, somehow knew it was an obvious/simple solution.
  • Kate Perkins
    June 13, 2010 at 5:31 pm
    Glad to help
    June 17, 2010 at 7:59 pm
    I ended up running Disk Warrior and that did the trick.
    Editor, Producer, Video Journalist
    619-206-9711
    San Diego, CA
  • Ryan Atkins
    September 25, 2010 at 7:57 pm
    Thank you very much for this fix. Although, I could probably run Disk Warrior again, just to have a happy Mac.
    My filters and effects were turned off, and could not figure out why.
    This worked for me – greatly appreciated.
Page 1 of 3
