Activity › Forums › Adobe Premiere Pro › File Types
File Types
Posted by Mike Mcvittie on April 20, 2012 at 7:57 pmI was watching a video Rich did and he had so many more file types in his Premiere and media encoder than I do. How do I start adding these extra file types?
MikeSony NXCAM
Todd Kopriva replied 14 years, 5 months ago 5 Members · 7 Replies -
Jeff Pulera
April 20, 2012 at 8:37 pmHi Mike,
Are you working with a trial version? That won’t have all codecs due to licensing and royalty concerns. If this is a full licensed install, it ought to have everything by default.
Jeff Pulera
Safe Harbor Computers -
Mike Mcvittie
April 20, 2012 at 9:08 pmThanks. I do have a full version but do not have near as many as Rich had in his tutorial. I am trying to output a .mov file but the highest quality format is 720 x 480 “in Media Encoder.
MikeSony NXCAM
David Mcgavran
April 21, 2012 at 4:14 amIf that is true something is very wrong… AME has had many many different output options for a long time. Can you post a screen shot?
Cheers
Dave
Andy Edwards
April 24, 2012 at 10:16 pmThose are the standard presets for “Quicktime.” You can customize the preset to make it HD by going to the video tab once you have chosen an NTSC preset. Choose your HD format codec and audio options, save it and it will show up the next time you choose quicktime.
I have not seen the video you talked about above, but maybe he chose an MPEG2, H.264 or P2Movie export format? Those choices have a ton of presets in the pull down menu.
Hope this helps.
Andy Edwards
Mike Mcvittie
April 25, 2012 at 6:36 pmThank you thank you!!!
that is all I needed to know. again thanks
MikeSony NXCAM
Todd Kopriva
April 27, 2012 at 4:09 amBTW, the comment about limited formats in the trial version is out of date. There are no limitations to the trial version other than that it expires in 30 days. See this:
https://adobe.ly/hcOibb———————————————————————————————————
product manager, professional video software
After Effects team blog
Premiere Pro team blog
