Activity › Forums › Blackmagic Design › Field reversal issue
  • Field reversal issue
    Posted by David Braswell on January 27, 2006 at 3:28 pm
    Using a Decklink SP here with 5.31 and WinXP Pro on a Blackmagic “blessed” SuperMicro MB w/2G RAM. I’ve an 8 bit Blackmagic project (D1, 720×486) where I’ve loaded Beta SP video through the component connection. On the same sequence timeline I’ve also placed DV footage ingested via firewire from a DSR-45. Any effect I apply to the DV footage and render produces a stuttery, strobed look in the rendered footage. Is this a consequence of mixing DV footage with D1 resolution footage, or am I experiencing other problems?
    Incidentally, a recently applied dissolve between the Beta and DV footage showed a slight shift in position of the incoming DV footage in the dissolve.
    David Braswell replied 20 years, 8 months ago 3 Members · 5 Replies
  • Shane Chadder
    January 27, 2006 at 3:44 pm
    Yes DV gets shifted (up I think) a line during rendered FX so the fields end up reversed. A workaround is reversing the fields or shifting the video down a line for the duration of the render.
    I’m not sure if this is fixed in 5.4 or not. I didn’t notice the problem in a peice I am currently working on in 5.4.
    Is it fixed Luke? Matt?
  • Shane Chadder
    January 27, 2006 at 9:01 pm
    I take that back. No it isn’t fixed in 5.4, not with PPro1.51 anyway. So you’ll need to reverse the fields or shift the video down a line for the duration of the FX.
    Shane
  • Jeff Brown
    January 28, 2006 at 6:09 pm
    I believe this happens due to the 480 footage being centered in a 486 image, so it’s moved down 3 lines (or up 3 from the bottom). Shifting interlaced footage up or down by an odd number of lines is the equivalent of reversing fields. Move it up or down 1 more pixel/line as Shane suggests, and you have an even # shift, so no field reversal.
    I go with reversing the field interpolation, as it’s easier for me to remember to do. But they should give equivalent results… in a perfect world, anyway.
    -jeff
  • Shane Chadder
    January 28, 2006 at 7:22 pm
    There is another work around I’ve tried breifly. When you are done capturing you can create a black magic NTSC 4×3 8bit job but go into custom settings and set the height at 480 instead of 486. Import your work into this job for editing.
    I only did a little work this way so I’m not sure its perfect.
    Shane
  • David Braswell
    January 31, 2006 at 2:20 pm
    Thanks everyone for your help with this. Reversing fields and re-interlacing did fix the fielding issue.
