Activity › Forums › Adobe Premiere Pro › field order
  • field order
    Posted by Sergio Barrozo on June 2, 2008 at 8:51 pm
    I have imported a QuickTime footage from an AVID system rendered upper field first.
    I then put it in Premiere 2.0 in track one and added a graphic with motion effect in track 2. In the field options of track 1 (the one with my video rendered upper field first) I choose the “Reverse Field Order” option.
    Then I exported it to DVD. When I played the DVD I have noticed that it was running with a wrong field order, but the motion effect I have created with a graphic in track 2 was correct.
    I then returned to Premiere and disabled the “Reverse Field Order” option in track 1. I exported the sequence again to DVD and it played again with the wrong field order.
    What’s the workaround here?
    Jeff Brown replied 18 years, 4 months ago 3 Members · 5 Replies
  • Jeff Brown
    June 3, 2008 at 2:33 pm
    Some details will help trace your problem:
    What are your project settings? (NTSC, PAL, D1, DV, HD, HDV, etc.)
    What is the footage you are importing (pixel dimensions and PAL/NTSC)?
    What codec was used to make the QuickTime?
    -jeff
  • Sergio Barrozo
    June 3, 2008 at 3:40 pm
    Hi Jeff,
    The project is set to NTSC DV
    The footage is QuickTime 720 x 486 rendered in After Effects – upper field
    Avid ABVB codec
    Thank you for your help.
  • Colin Browell
    June 3, 2008 at 11:02 pm
    I think that reverse field order is an instruction as to how that clip should be re-rendered IF it is necessary for it to be re-rendered (due to an effect or transition).
    If there’s no need to re-render it, then the clip will just be copied as-is to output, so the field order will not actually change.
    DV is lower field-first, so if you are able to recreate the upper field clip as lower-field first this is probably the best solution. Otherwise you can take the upper-field-first clip and shift all the lines vertically by a single scan line – that will change it to lower-field first but lose the top (or bottom) scan line.
  • Sergio Barrozo
    June 3, 2008 at 11:44 pm
    I remember that sometime ago I heard about this procedure.
    I’ll try it.
    Thank you.
  • Jeff Brown
    June 4, 2008 at 3:15 pm
    Shifting up (or down) one pixel is probably the best solution to try. The problem arises from putting 486-high footage into a DV project, which is 480 high. If the image is centered, you get a 3-line shift, which reverses fields. Also contributing to problems is that in some AVID software, the upper/lower field choice is backwards from everyone else; i.e., they use upper = odd field first, whereas the rest of the world has standardized on upper = even field first, so I’m never sure what to trust with AVID… That could just be my problem.
    -jeff
