Activity › Forums › DaVinci Resolve › Feature Request Color Temp/Tint sliders
Posted by Lee Niederkofler on September 6, 2011 at 10:30 pmHi,
I’ve just worked on some stills in Lightroom, and I find the Color Temperature and Color Tint sliders are very useful for creating looks or just to get a quick White Balance.
I know Speedgrade has them too and I always found them quite useful there.
Am I the only one missing them in Resolve?
best
leeJoseph Owens replied 15 years ago 7 Members · 9 Replies -
Blase Theodore
September 7, 2011 at 12:40 amId be curious if those are actually implementable. Obviously in RED footage or a raw photo editing platform, you’re working with raw debayer info, and can actually interpret the data. Once its baked in though to a quicktime or frame, not sure how that would work. (Just like you can pick a color temp for a raw still in photoshop, but after that you can only tint it.)
Illya Laney
September 7, 2011 at 2:41 amColor temp in regards to non-raw material is basically blue/orange bias and tint is usually magenta/green bias. If there’s no raw data involved, color temp values are arbitrary. Tint is useful when working with multicam Alexa footage because there always seems to be a green/magenta bias between the different cameras. If you want an approximation right now, the green curves can be used instead of a dedicated tint slider.
twitter.com/illyalaney
nextLAB Mobile
SpeedGrade DI
Resolve
da Vinci 8:8:8 Renaissance
Color -
Blase Theodore
September 7, 2011 at 2:55 amI’d say the new color mixers basically reproduce this functionality. Correct me if I’m wrong.
Mike Most
September 7, 2011 at 3:48 amYou’re not wrong. A color temperature control is basically a variable matrix.
Mike Most
September 7, 2011 at 4:27 amTo perform a color temperature operation, you can lower the amount of blue in the blue channel, and raise the amount of blue in the red channel to achieve a lower color temperature (i.e., more orange). Conversely, you can lower the amount of red in the red channel, and raise the amount of red in the blue channel to achieve a higher color temperature (i.e., more blue). To change tint, you can lower the amount of green in the green channel for more magenta, and raise it for more green.
Paul Jay
September 7, 2011 at 10:18 amI would love to have a RAW STILL editing mode in Resolve.
I want to grade my photographs as i do in lightroom but with DaVinci + Control Surface.
I can’t believe why nobody has done it 😛Grading 25 MP RAW Photograps with a Color Grading Control Surface is a dream if you ask me.
Dan Moran
September 7, 2011 at 10:20 amI’ve converted my RAW files to TIFF’s and tried just that 🙂
It was a dream!
D
Dan Moran
DaVinci Application Specialist
Blackmagic Design EMEA -
Lee Niederkofler
September 7, 2011 at 11:42 amThanks, I’ll try it with the new mixer tool. I didn’t thought of that…
I know that the temp/tint slider is normally used for raw files like r3d or canon cr2 files in lightroom but In Iridas Speedgrade I’ve used them all the time on non raw files either and they worked great…
Best
Lee -
Joseph Owens
September 7, 2011 at 5:37 pmYou might get a sense of why from this thread from about 15 or so years ago…
https://www.colorist.org/pipermail/oldtig-mhonarc/1996/msg01702.html
Some techniques are protected by manufacturers… anyway, lots of sliders? You’d have loved the Dubner.
Ever wonder why the area isolation in COLOR was called “vignettes” when “power window” is a perfectly good term? How about “Kilovectors”?
jPo
You mean “Old Ben”? Ben Kenobi?
