Activity › Forums › Apple Final Cut Pro Legacy › FCP7 and FCPX on Mac OS 10.7 LION is bad idea
  • FCP7 and FCPX on Mac OS 10.7 LION is bad idea
    Posted by Everest Mokaeff on July 5, 2011 at 3:58 pm
    Just to confirm what was reiterated all over this forum: FCS3 can’t sit well on Mac OS 10.7 Lion if FCPx, or Motion 5, or Compressor 4 installed altogether. After installing additional content for FCPx and Motion, I got Compressor 3.5.3 and Motion 4.0.3 not functioning either as stand-alone applications (generate system compatibility error) or as parts of FCP7 round-trips workflows. Remedy: use fcs remover and manually get rid of FCPx/Motion 5/Compressor 4 stuff. Reinstall FCS3 from disks and update.
    Hope, it’ll do.
    Sony PMW-EX3, Canon Mark II 5D, FCS3 in Moscow
    http://www.mokaeff.com
    Rick Lang replied 15 years, 2 months ago 5 Members · 12 Replies
  • 12 Replies
  • David Roth weiss
    July 5, 2011 at 4:13 pm
    Or, you could have taken my advice/warning from my tutorial (published well in advance of the June 21 roll out) and installed FCP X, Motion 5, and Compressor 4 on a separate partition, which would have prevented these issues and saved you lots of extra work.
    Here’s the tutorial in case you missed it:
    https://library.creativecow.net/weiss_roth_david/FCP-10-MAC-Lion/1
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    Don’t miss my new tutorial: Prepare for a seamless transition to FCP X and OS X Lion
    Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
  • Rafael Amador
    July 5, 2011 at 4:14 pm
    [Everest Mokaeff] “Just to confirm what was reiterated all over this forum: FCS3 can’t sit well on Mac OS 10.7 Lion “
    How can be confirmed anything about Lion?
    Does anybody have tried yet?
    rafael
    http://www.nagavideo.com
  • Everest Mokaeff
    July 5, 2011 at 4:30 pm
    Yes, it’s out there for long time. Unlike FCPx Lion is not that big secret on developer’s stage.
  • Arnie Schlissel
    And you know this because you’ve installed Lion, which isn’t releases yet? Or are you just spreading more FUD type rumors?
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Everest Mokaeff
    July 5, 2011 at 4:33 pm
    Thanks David,
    for me it was quite reasonable risk to run. I wanted to push things a little bit around to see if things would change with updates installed. They changed. To restore and update FCS3 took me about seven minutes, though, I skipped Soundtrack Pro content)))
  • David Roth weiss
    July 5, 2011 at 4:35 pm
    I just need to keep reminding people here for obvious reasons Everest.
    I’d rather try to help Cows avoid these issues altogether, because helping them to fix these problems after the fact can be exponentially more complicated.
    David Roth Weiss
    Los Angeles
  • Everest Mokaeff
    July 5, 2011 at 4:45 pm
    100 % agree with that. I just tried to say that it’s not that bad if you messed up a little bit. You still can return to where you stood at the beginning without re-installing mac os from scratch. Certainly it requires some level of diligence and expertise both dealing with OS and FCS.
  • Rafael Amador
    July 5, 2011 at 4:49 pm
    [Everest Mokaeff] “Yes, it’s out there for long time. Unlike FCPx Lion is not that big secret on developer’s stage.”
    Lion is expected to be released by the end of this month:
    https://www.apple.com/macosx/
    rafael
  • Everest Mokaeff
    July 5, 2011 at 4:57 pm
    Arnie,
    please read carefully what I said in this post before questioning me.
  • Arnie Schlissel
    July 5, 2011 at 5:02 pm
    [Everest Mokaeff] “please read carefully what I said in this post before questioning me.”
    I did. I will repeat my question. Do you know this because you have installed Lion, which is not yet released?
    Arnie
