Activity › Forums › AJA Video Systems › FCP getting repetitively sluggish with Kona LHi
Drew Kilcoin replied 16 years, 5 months ago 5 Members · 30 Replies
Drew Kilcoin
April 8, 2010 at 5:04 pm -
Drew Kilcoin
April 8, 2010 at 9:20 pmSo I switched around my slots and moved my storage to slot 2 and the Kona to SLot 3.. Lets hope it helps. But I did run the Aja System test on my drives and they were way slower than day before when in slot 4. But keeping my fingers crossed
Drew
https://www.imdb.com/name/nm2398405/ -
Drew Kilcoin
April 12, 2010 at 6:13 pmwell I know my luck wasn’t good enough. we got the flicker/screen image stutter to happen again..DAMN! it’s just so annoying. This is after I switched my Storage card to slot 2 and AJA Kona LHi to Slot 3. Jeremy I am now going to physically take out the memory like you said. All I can think now that it has to be something with FCP7 and the card. Again we even went back down to 10.5.8 to see if that would help… thanks jeremy for trying to help
Drew
David Soll
April 12, 2010 at 6:23 pmSorry for the blank post.
Have you tried contacting AJA for a replacement card? They had one to me overnight, and it turned out I didn’t even need it.
Drew Kilcoin
April 12, 2010 at 6:32 pm -
Jeremy Garchow
April 13, 2010 at 5:22 pm[Drew Kilcoin] “All I can think now that it has to be something with FCP7 and the card.”
or a deeper issue with your computer hardware.
Drew Kilcoin
April 13, 2010 at 6:54 pmYou know it’s starting to look more and more like Final Cut Pro’s terrible Merged Clip Functionality. Our problem seems to happen a lot we we get heavy into trim mode. We are working with merged clips(audio from one source, Video from another). FCP has had major problems with Merged clips(matchframe, Crash on trimming, trim function acting strange) which I have brought up with Apple Engineers and they are suppose to be working on it.
Anyways our situation seems to happen a lot during heavy use of trim mode and we had a very similar problem with a Blackmagic Intensity Pro. It would crash very regularly in trim mode. reason why we switched to the AJA Kona Lhi. But it seems to be the common thing. It’s just a hunch of mine, for now on I will not be merging clips in FCP until they can make it stable like Autosync in AVID. Just going to have to take the time to Batch Export all merged clips to make them a self contained quicktime.
Drew
Jeremy Garchow
April 13, 2010 at 6:57 pm[Drew Kilcoin] “FCP has had major problems with Merged clips(“
I would suggest deleting all of your caches (thumbnail, waveform, and the ones in your ‘Final Cut Pro User Data’ folder.
So, save and quit FCP, delete all those caches, then reopen.
This has helped me with merged clips in the past.
Jeremy
Drew Kilcoin
April 13, 2010 at 7:02 pmOne step ahead of you. I do this almost every day at lunch with the FCS Management Pack by Digital Rebellion. I even log in and log out the user to try and make it help. No difference. Thanks for still making suggestions.
Drew
