Activity › Forums › AJA Video Systems › FCP getting repetitively sluggish with Kona LHi
  • FCP getting repetitively sluggish with Kona LHi
    Posted by David Soll on April 4, 2010 at 11:12 pm
    I’m a new Kona LHi owner. While editing, every ten-twenty minutes my timeline navigation becomes strangely sluggish, taking 10 seconds or so to respond to commands. This is immediately solved by “refresh a/v devices,” which leads me to believe it has something to do with my FCP-Kona communication. Any thoughts about a permanent fix for this?
    It’s a little annoying to keep hitting option+F12, but not the end of the world. Mostly, I’d just like to understand what’s happening.
    Mac Pro 2×2.93 quad core xeon, 32gb RAM, OSX 10.6.3
    FCP 7.0.2
    Kona LHi 7.5.1 with breakout box
    Projects are all SD, Setup: AJA Kona LHi: 525 29.97 Apple ProRes 422
    Footage is coming SD-SDI in from Digibeta, outputs are Component to broadcast monitor and SD-SDI to D-Beta
    David
    Drew Kilcoin replied 16 years, 5 months ago 5 Members · 30 Replies
  • 30 Replies
  • David Soll
    April 5, 2010 at 12:52 am
    Also, my slot arrangement:
    1: ATI Radeon
    2: Kona LHi
    3: eSATA (glyph) card
    4: empty
    Some things I already tried:
    AJA conflict checker: all good
    Trashed FCP prefs
    Uninstalled/Reinstalled Kona drivers
  • Scott Davis
    April 5, 2010 at 6:27 pm
    Is it your hard disc going to sleep? Look in system prefs, under “energy saver”, and uncheck “put hard disc to sleep when possible”. Might be the problem, might not but it should be unchecked for an edit system anyway.
    Scott Davis
    View Scott Davis's profile on LinkedIn
  • Jeremy Garchow
    April 5, 2010 at 7:07 pm
    I think you want your LHi in slot 3 and your storage card in slot 2.
    Jeremy
  • David Soll
    April 5, 2010 at 7:58 pm
    Thanks for the thoughts, guys.
    Scott: My energy saver prefs are set for hard drives to not go to sleep, so that’s not it. I’ve learned that lesson before. Also, when I’ve dealt with hard drives slowing me down in the past, especially externals, I could actually hear them spinning up to speed while I was waiting for FCP to respond. In this case, hitting option+F12 restores response time instantaneously, with no noticeable hard drive chatter.
    Jeremy: Your suggestion is actually how it was originally installed for me (by Tekserve in NY), but AJA tech support, and their documentation, has it spec’d for the AJA card in slot 2 (according to AJA tech support, slots 1 and 2 are the “fast lanes” on a Mac Pro). So I switched the eSATA to 3 and the AJA to 2.
    Any other thoughts out there, short of trying a new LHi?
    David
  • Jeremy Garchow
    April 5, 2010 at 8:04 pm
    [David Soll] “has it spec’d for the AJA card in slot 2 (according to AJA tech support, slots 1 and 2 are the “fast lanes” on a Mac Pro). So I switched the eSATA to 3 and the AJA to 2. “
    It would depend on the vintage of your MacPro. Do you have a Nehalem machine?
  • David Soll
    April 5, 2010 at 8:40 pm
    Yeah, Nehalem. Just came out of the box Thursday.
  • Jeremy Garchow
    April 5, 2010 at 8:47 pm
    My Nehalem has Storage in slot 2, Kona in Slot3.
    Jeremy
  • David Soll
    April 6, 2010 at 11:01 pm
    Switching to the NDD driver seems to have fixed the issue. Something I should have done before posting, but oh well. All good now.
    Jeremy – I’m concerned that you and I heard different slot specs from AJA. Can you post a link the recommendation for slot 3 on Nehalem machines?
  • Jeremy Garchow
    April 7, 2010 at 2:56 pm
    I don’t have a link, just an email from AJA support:
    “Subject: RE: Latest Mac Slot configuration Intel Xeon “Nehalem” processor
    If they have a Kona 3 or Kona-LHi:
    > Slot-2: Atto
    > Slot-3: Kona
    > Slot-4 SATA
    > If they have a Kona-LSe or Kona-LHe: It must be installed in slot-2.”
    I have an ATTO R380 SAS card that requires 8 lanes. That’s why it’s in slot 2, and Kona in 3.
    Jeremy
  • David Soll
    April 7, 2010 at 3:40 pm
    I see. So there’s no controversy that slots 1 and 2 are the “fast lane” slots, just that your storage solution seems to trump your Kona on which should get the fast lane slot?
Page 1 of 3
