Activity Forums Apple Final Cut Pro Legacy FCP can’t see DSR-11 deck — why not?
  • FCP can’t see DSR-11 deck — why not?
    Posted by Jeff Nelson on July 17, 2007 at 3:55 am
    I have some footage shot on full sized DVCAM and my regular deck only plays the mini-dv flavor. So I borrowed my neighbor’s DSR-11 deck. It plays the tape, I can monitor it with an S-cable hookup, but FCP is not seeing the deck. I plugged the same deck into my old PC to see if I could see it there in Premiere Pro, no dice.
    Does this suggest a bad firewire out? Or… I know the firewire cable is working okay. Any suggestions of what I might be doing wrong? Got the easy setup for DV NTSC.
    Thanks.
    Jeff Nelson replied 19 years, 2 months ago 4 Members · 8 Replies
  • 8 Replies
  • Steve Eisen
    July 17, 2007 at 3:59 am
    Did you make sure the decks input is set to DV?
    Steve Eisen
    Eisen Video Productions
    Director-At-Large
    Chicago Final Cut Pro Users Group
  • Jeff Nelson
    July 17, 2007 at 4:05 am
    Hi, thanks. Yes, the DV and NTSC lights are lit, and the picture and sound plays back fine through the S-cable into my monitor. But FCP doesn’t see the deck.
  • David Peralta
    July 17, 2007 at 4:54 am
    try zapping the p-ram. works for me every now and then
    hmm… I wonder what this button does…
  • Jeff Nelson
    July 17, 2007 at 5:48 am
    Zap the p-ram?? Could you explain?
  • Jeremy Garchow
    July 17, 2007 at 4:50 pm
    Can your neighbor get it to work through firewire?
  • Jeff Nelson
    July 17, 2007 at 4:57 pm
    He’s going to try it on his system tonight, thanks…
  • David Peralta
    July 18, 2007 at 1:57 am
    When you boot up, hold down apple+opt+P+R and hold down for 2 gongs, what that will do is reset your parameter ram. When i cant see my firewire drives and its not being detected, ill restart and if still not mounted, ill restart again and then “ZAP the p-ram”
  • Jeff Nelson
    July 18, 2007 at 10:47 pm
    Thanks for the tip. Turns out to be a bad firewire out on the deck. But good to learn this tip.
