Activity › Forums › Apple Final Cut Pro Legacy › FCP 5.1.2 capture drop-frame media to a non-drop frame clip BUG?
  • FCP 5.1.2 capture drop-frame media to a non-drop frame clip BUG?
    Posted by Peter on December 7, 2006 at 5:23 pm
    After getting the following message upon batch capture, DV-NTSC easy set-up, Panasonic DV2500 VTR:
    Warning: You are about to capture drop-frame media to a non-drop frame clip. If you proceed, you may experience changes in logged in and out points, problems relinking media, or removal of master clip relationships.
    …I read through posts here with others having the same problem. I brought the tape over to another FCP station, FCP 5.0.4, Sony DSR-45 Deck and tried a batch capture which worked flawlessly. I then brought the Panasonic DV2500 VTR over to this station and that worked flawlessly as well.
    So I think it’s fair to say that it’s not the tape record or deck settings that are causing the error.
    Is this a known bug in 5.1.2 or is there a workaround that anyone knows? I see others are having lots of capture setting issues with 5.1.2 as well.
    Thanks in advance.
    Everythng on system is as up-to-date as possible
    FCP 5.1.2
    OS X 10.4.8
    QT 7.1.3
    Robert Depalma replied 19 years, 9 months ago 7 Members · 18 Replies
  • 18 Replies
  • Mark Maness
    December 7, 2006 at 5:44 pm
    I have seen this one many times myself.
    The only solution I have used was to restart the computer and try it again. Most of the time it works, other times, I have to create a new clip and capture that clip instead.
    Have you seen the changing timecodes, yet? Sometimes when I redigitize a clip, the timecode gets shortened by some various length. This happens alot too.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
  • Peter
    December 7, 2006 at 6:21 pm
    It just cropped up this morning so I haven’t gone any further with the project on that computer….Huh, from your expereince and what a lot of other are saying the most up-to-date combo is really problematic with digitzing and time code. Someone mentioned QT 7.1.3 being the issue. Do you have any idea if Apple is aware of this and/or how to submit a bug report to them?
    thanks in advance.
  • Mark Maness
    December 7, 2006 at 8:01 pm
    [Peter] “Do you have any idea if Apple is aware of this and/or how to submit a bug report to them?”
    Well, Peter, everytime is happens, I submit a feedback form and hopefully everyone else is doing the same. As for this issue, its been happening ever since upgrading to version 5.1.2. But we use the XDCM HD system and this update was necessary to us.
    Wayne Carey
    Schazam Productions
  • Peter
    December 7, 2006 at 8:06 pm
    I think it can be traced to 5.1.2 too. I have OS 10.4.8 and QT 7.1.3 on another computer with FCP 5.0.4 and everything is fine. I’ll submit a form as well – thanks for your input.
  • Jeremy Garchow
    December 7, 2006 at 9:43 pm
    To complicate matters, this started for me after updating to 7.1.3 (when the the latest version of iTunes came out). This was before I even had 5.1.2.
    Jeremy
  • Peter
    December 7, 2006 at 10:14 pm
    I just made a report to apple – not easy to find this page on their site, https://www.apple.com/feedback/finalcutpro.html
    Hopefully it’ll be addressed in the update…
  • Gary Adcock
    December 7, 2006 at 10:25 pm
    I saw the later stages of these posts and want to ask a dumb question.
    Are you trying to capture to 24p ( 23.98) from the 29.97 SD stream?
    if so this warning is correct (but annoying)
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
  • Peter
    December 7, 2006 at 10:29 pm
    I am trying to capture 24p panasonic material when this happens. I’ve done it many many times though via the DV-NTSC 29.97 easy setup on other computers pre FCP 5.1.2 and never had a problem. It’s the old standard way of capturing 24p normal mode into FCP.
  • Gary Adcock
    December 7, 2006 at 10:50 pm
    [Peter] “I am trying to capture 24p panasonic material when this happens. I’ve done it many many times though via the DV-NTSC 29.97 easy setup on other computers pre FCP 5.1.2 and never had a problem. It’s the old standard way of capturing 24p normal mode into FCP”
    I guessed that.
    It’s that FCP has gotten smarter in the latest builds.
    24p (23.98) content is Non Drop and 29.97 is Drop Frame.
    So the dialog is actually correct, even if you have never seen it before, it is just that with al of the changes in FCP to capture 24p materials Apple has added the dialog to make sure that users understand that they are changing the timebase of the content they are capturing.
    gary adcock
    Studio37
  • Jeremy Garchow
    December 8, 2006 at 12:23 am
    [gary adcock] “It’s that FCP has gotten smarter in the latest builds”
    FOr every reaction, there is an equal but opposite reaction. This happened to me recently (I know there’s a thread on it somewhere) where I captured regular DV-NTSC over firewire for the first time in a really long time. The footage was regular ole dv, not 24p, and I’d get that message. After capturing, the timecode and other metadata would disappear from the browser. It was frustrating to say the least. My hunch was that the latest version of Quicktime has busted it because it started happening after that update. I have not seen this error in a while, but it’s been a pretty HD filled fall and winter and I capture that w/ the Kona and it’s been no worries there except for some weird 10 bit scaling, but that’s another matter.
    Jeremy
