Activity › Forums › Apple Final Cut Pro Legacy › FCP 5.1.2 capture drop-frame media to a non-drop frame clip BUG?
Robert Depalma replied 19 years, 9 months ago 7 Members · 18 Replies
Peter
December 8, 2006 at 3:35 pmThanks Gary – that’s interesting. Do you think apple only needs to tweak the error message, not the actual functionality of FCP 5.1.2? In your opinion is it then safe to kit “ok” and move on as normal? I’ll need to media manage the project down the line and want to avoid relinking problems.
Jeremy Garchow
December 8, 2006 at 4:05 pmAs long as after your capture, your meta data is still there, you should be good to go. You can also double check and make sure that your firewire deck control is set to NDF (firewire usually defaults to DF).
Jeremy
Gary Adcock
December 8, 2006 at 5:15 pm[Peter] “. Do you think apple only needs to tweak the error message, not the actual functionality of FCP 5.1.2? In your opinion is it then safe to kit “ok” and move on as normal?”
Why does apple need to tweak the dialog? It is not an error message.
You are capturing 23.98 non drop content from a 29.97 drop frame tape. Just because people do not know that 24p content is NDF is not really Apples responsibility, it is yours, as the editor to know that. There is a more to working in 24p than just grabbing the easy set up, you have to learn about shutter angle, panning motion, pulldown, dupe frames and what working progressive is actually all about.
it is what it is, there is not a way for you as a user to change the timebase. Clicking on “OK” means you understand what that means.
Welcome to the World of HD -even though you are working from an NTSC stream, the rules apply the same now.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows -
Peter
December 9, 2006 at 12:25 pmThere are a lot of people here who may ask questions that are far below the knowledge of others. But equally, there are a lot of people here who answer them with a serious chip on their shoulder. There’s no need to be condesending with your opinion. You may or not be right yourself. Try to stay positive. It’s more constructive and you’ll probably feel better, less angry.
Thanks for you opinion. We’ll all take it into consideration.
Walter Biscardi
December 9, 2006 at 1:12 pm[Peter] “Thanks Gary – that’s interesting. Do you think apple only needs to tweak the error message, not the actual functionality of FCP 5.1.2? In your opinion is it then safe to kit “ok” and move on as normal? I’ll need to media manage the project down the line and want to avoid relinking problems.”
No, it’s just like Gary says, the message is there as a reminder to the Editor that you are about to change the editing timebase. Your hitting “Ok” acknowledges that you understand what it is saying.
I’m not sure what you would want Apple to tweak there. It’s a pretty straightforward message.
Walter Biscardi, Jr.
HD Editorial & Animation for Food Network’s “Good Eats”
HD Editorial for “Assignment Earth”“I reject your reality and substitute my own!” – Adam Savage, Mythbusters
Accountclosed
December 18, 2006 at 6:14 pmHey Gary – Welcome to the world of humility… calm down a little, eh?
This thread started from people who are having actual issues with FCP 5.1.2.. whether or not you are superstar FCP man or not, people need help in this forum, not attitude.
I log and capture all day long, and ever since the upgrade, I get the same dialog box, and I don’t touch anything HD, all DV SD, bro… and I still get that message for no apparent reason, and the media is NOT NDF, good ol’ 29.97 NTSC SD DV.
Jeremy Garchow
December 19, 2006 at 4:26 pmYep, me too. It’s definitely more than a 24p in NTSC deal.
Jeremy
Robert Depalma
December 28, 2006 at 12:16 amThis may be a late response, but for all of those searching for answers in the future, this may be one:
I had the same warning and I didn’t realize that under “Capture Settings” tab in the Log & Capture box, I didn’t check the Anamorphic box. When I checked it, the warning didn’t pop up. Of course, I’m working with anamorphic footage, so it applies.
Hope this helps someone!r
