Activity Forums Apple Final Cut Pro Legacy FCP 5 wishy washy
  • Tunaking
    June 16, 2005 at 8:48 pm
    Full install. Tiger. No problems.
    I’ve edited HDV, multicam, 10-bit uncompressed HD and SD, DV, DV50.
    Working with Kona 2 and Xserve RAID.
  • Uwe Klimmeck
    June 16, 2005 at 9:55 pm
    It’s working fine here. No problems (sluggish J-K-L of course) but that’s it.
    Very stable with DecklinkPro, no crashes with FC5. Two crashes with Motion, sync problems with Decklink drivers and AfterEffects, but FC5 is almost perfect,
    Greetings
    Uwe
    FC Studio / DLpro / SDconnect / Dual 2.7 / Dual 1.4 / Dual iPod / http://www.fcpmunich.com
  • Stuart Ferreyra
    June 16, 2005 at 10:26 pm
    The main thing to do is:
    1) Clean Install of OS
    and
    2) Clean Install of FCP / Creative Suite.
    I bet the ones with the problems did not do that.
    Even though it takes time. It saves a lot of headaches.
    Stu
  • Jerry Hofmann
    June 16, 2005 at 11:25 pm
    You can hear the audio in the log and capture window if you turn on the “preview” button in the Clip settings tab in the L&C window…
    Jerry
  • Jerry Hofmann
    June 16, 2005 at 11:28 pm
    Steve, you’ve hit the nail on the head CLEAN INSTALL… if you don’t do this, ESPECIALLY if you going to Tiger you aren’t going to be happy don’t think.
    In every case I’ve read about here, and in Apple’s forum, when problems like the ones described here show up it’s becase the install wasn’t a clean one.
    ANY time you go to a new OS, it’s time for an erase and install of a startup disk. Doesn’t even have to be the same one you’ve been using at all. A second internal or FireWire drive works fine for this… installing FCS on 10.4.1 cleanly really makes a difference.
    Jerry
  • Aaron Neitz
    June 16, 2005 at 11:31 pm
    But you CAN’T hear it in the Edit to Tape window. So if you want to make a quick buzz through and confirm audio went down…. you can’t. Little things that used to work…they don’t anymore.
  • Tom Wolsky
    June 16, 2005 at 11:33 pm
    Have you made that work Jerry? I tried it on a couple of machines and didn’t have much luck with it.
  • Tom Wolsky
    June 16, 2005 at 11:35 pm
    Sounds like an AJA problem. I haven’t seen anything like that. What do they say?
  • Tom Wolsky
    June 16, 2005 at 11:37 pm
    What’s that mean, I have to separate the bins manually? What’s the layout and what happens when you create it, apply it? FCP always had problems with some layouts, overlapping windows, cross monitor windows. I haven’t seen one that’s bin specific.
  • Jerry Hofmann
    June 16, 2005 at 11:39 pm
    I’m not having any trouble hearing audio thru the computer’s speakers with the preview button on with a Kona 2 setup or direct from a DSR-11…
    Jerry
Page 2 of 4
