Activity › Forums › Adobe Premiere Pro › Favourite Deinterlace method?
  • Favourite Deinterlace method?
    Posted by Trevor Asquerthian on September 24, 2014 at 9:28 pm
    Using Clip | Field options | Deinterlace is a bit clunky, has to be done one clip at a time, can’t be copy/pasted and there is no indication of the current setting.
    And there is no option to use ‘field 2’.
    What are the best deinterlace options out there? ReVision FieldsKit? BCC Deinterlace? After Effects methods?
    Steve Knattress replied 11 years, 10 months ago 3 Members · 2 Replies
  • Robert Withers
    September 26, 2014 at 1:48 am
    I’ve tried the Red Giant Frames Plus plugin and it seems to work–gives you a few options. Then the Red Giant Instant HD to uprez. Seemed to work. Lots of processing though, and glitches exporting through AME. I’ve found I needed to apply these effects to segments of a 30 minute timeline, not to the whole.
    I’ve heard some people use AE for deinterlace.
    Robert Withers
    Independent/personal/avant-garde cinema, New York City
  • Steve Knattress
    November 24, 2014 at 6:18 pm
    I have a sequence edited form ProRes422 1080i50 clips ( originally captured from HDV deck in AvidMC exported as prores to a lace thunderbolt SSD drive) , which I am trying to deinterlace using BCC 8.3 with the latest PremierPro CC on a 2011 i7 MacBookPro with Yosemite 10.10.1
    I am getting many crashes if I try to add to all the timeline clip.
    Any that I render (preview files same PRORES) I get many glitches, some with wrong colours, others with parts of the frame inverted, or whole frames inverted, usually a couple of glitches every 2 sec or so.
    After adding the BCC (no timeline colour to red line) the computer gets very slow and often completely crashes resulting in a automatic reboot.
    I have an aja io xt, but get the same problems whether its connected or not.
    Any ideas?
