Activity › Forums › Adobe Premiere Pro › Faking A Neutral Density For Skies
  • Faking A Neutral Density For Skies
    Posted by Deke Ryland on January 25, 2008 at 9:15 pm
    Okay… I have my source landscape clip, with blue sky sitting in top half of shot.
    I put that in Video Track 1.
    Then I make a black video clip and place it in Track 2.
    I apply a Ramp (blck->white from top to bottom) to track 2.
    Then I go to the landscape clip in Track 1 and apply Calculations effect to it. I set the “Second Source 2nd Layer” to Video 2 and set “Second Layer Opacity” to 100%.
    I then set the blending mode to ‘Overlay’.
    PROBLEM:
    This works correctly for the top half of the gradient/landscape, but the bottom half where the ramp turns to white is lightening the ground.
    So it is effectively darkening the sky like I want, but it is brightening the ground. Why does it brighten the ground? It shouldn’t. I know it doesn’t do that in Photoshop at least. Shouldn’t white in the ramp turn to transparent? If not, how can I make it so the white in the ramp is transparent on the final shot?
    Thanks for any help!
    Ken Rodriguez replied 9 years, 8 months ago 4 Members · 3 Replies
  • Jon Barrie
    January 26, 2008 at 12:38 pm
    Change the ramp to Black – 50% grey or mask the bottom of it. Multiply should also give you a similar effect without white affecting your shot underneath. Fiddle with the opacity to get the best level of sky. I use this feature too and overlay does lift in the white – Even in Photoshop you probably haven’t noticed it.
    – JOn 🙂
    How many editors does it take to change a light bulb?
  • Steven L. gotz
    January 28, 2008 at 9:17 pm
    Or change the ramp to just cover the top of the frame.
    Steven
    https://www.stevengotz.com
  • Ken Rodriguez
    January 22, 2017 at 7:31 pm
    I know this is an old old post but I was having the same problem as you and I figured it out!
    Use a gradient image instead of ramp. Create one in photoshop and add it as a static image on top of your clip and modify the opacity.
    Also use a tiff. Tiffs can fade into a background as opposed to fading into white. Then it won’t brighten up the foreground when you bring up your opacity.
