Activity › Forums › Adobe Premiere Pro › Fade Out, Fade In Transition in Adobe Premiere Pro CC?!
Posted by Mark Jackson on May 17, 2015 at 12:21 pmIs there a fade out, fade In transition in Premiere Pro CC like the one in Final Cut Pro 7?
Mark D. Jackson
Mark Jackson replied 11 years, 4 months ago 4 Members · 7 Replies -
Ann Bens
May 17, 2015 at 5:27 pmWhat is so special about a fade in FCP7
Premiere has cross fade, film fade or make your own with bezier curves.———————————————–
Adobe Certified Expert Premiere Pro CC
Adobe Community Professional -
Mark Jackson
May 17, 2015 at 7:26 pmThe big difference is that you can fade out and in by applying one transition (Final Cut Pro 7) as oppose to adding 2 transitions and space (In Adobe Premiere Pro CC) between the two.
I’m fairly new to Premiere Pro CC, and I’m trying to streamline my workflow.
Mark D. Jackson
Andrew Kimery
May 17, 2015 at 11:10 pmMark are you talking about a Dip to Black transition? PPro has Dip to Black and Dip to White.
Mark Jackson
May 17, 2015 at 11:53 pmNo. It is a fade out, fade in transition that you can apply to two clips joined together.
Mark D. Jackson
Andrew Kimery
May 18, 2015 at 1:27 am[Mark Jackson] “No. It is a fade out, fade in transition that you can apply to two clips joined together.”
That’s exactly what PPro’s dip to black/white transition does. Drop it on an edit point and it will fade out the out-going clip and then fade-in on the incoming clip.
