Activity › Forums › Apple Final Cut Pro Legacy › Exporting 16×9 as 16×9 FHA
  • Exporting 16×9 as 16×9 FHA
    Posted by Steve Mullins on October 15, 2013 at 1:55 pm
    I have a Music Video that needs to be sent to the broadcaster meeting their spec.
    Thing is, they want AP 422 HQ at 1920x1080p – 16×9 FHA – sure if its squished up to FHA this wouldn’t be 16×9 ?
    How / what settings do I need to do to export a 1920x1080p as 16×9 FHA within FCP7 or MPEG Streamclip (which has all the below option bar a ‘anamorphic’ option).
    There is a 1080p AP 422 HQ Easy Set up with Anamorphic?
    Heres their spec
    Wrapper
    ProRes 422 HQ
    File Format
    MOV (QuickTime)
    Video Codec
    ProRes 422 HQ
    High Quality
    Video Bit-Rate
    N/A
    Video Frame Size
    1920 x 1080
    Aspect Ratio
    16:9 FHA
    Frame Rate
    25
    Profile@Level
    N/A
    Chroma Subsampling
    4:2:2
    GOP Structure
    N/A
    Field Dominance
    Interlaced
    Top Field First
    Audio Codec
    PCM
    Audio Bit-Rate
    N/A
    Audio Sampling Rate
    48 kHz
    Audio Sample Size
    24 bit
    Channel Mode
    2Ch Stereo
    Michael Gissing replied 12 years, 11 months ago 3 Members · 2 Replies
  • Shane Ross
    October 15, 2013 at 5:10 pm
    That spec makes ZERO sense. If the delivery was SD…it would, because SD is 4:3 only. So you either letterbox or squeeze…FHA. Except in the case of PAL, where even SD is 16:9.
    HD is not anamorphic…it is 16:9, period. Why someone is asking for 16:9 FHA 1920×1080…befuddles me.
    I guess you can make it 1440×1080….that’s 4:3.
    Shane
    Little Frog Post
  • Michael Gissing
    October 16, 2013 at 1:54 am
    Perhaps what they mean is they want the 16:9 to be without letterboxing to create a wider frame than 16:9. However the terminology is wrong. FHA specifically means anamorphic format which is not required when pixels are 1920 x 1080 and 16:9 already with square pixel.
    Better check that they do just want 1920 x 1080 16:9 square pixel.
