Activity Forums Apple Final Cut Pro Legacy EXPORT FOR WEB…(NEED ADVICE)
  • EXPORT FOR WEB…(NEED ADVICE)
    Posted by Andrew Wise on February 22, 2006 at 3:22 pm
    Hi All,
    I need some advice on the easiest way possible to convert a 5 min. project for use on the web. In this case I will need to provide a ‘web person’ with a format that they can use to incorporate the project into a web site. I am not familiar with ‘Compressor’ and would like to do it in FCP if that’s possible. I’ve spent the last hour looking over the archives on this subject and, I must admit, I’m more confused now than when I started.
    Is there no easy way to do this in FCP?
    or
    If I saved it as a quicktime file….can most web people convert quicktime files (.mov) to a format that will work on the web (universally)?
    Thanks in advance for any advice!!
    Andrew
    Andrew Wise replied 20 years, 2 months ago 9 Members · 23 Replies
  • 23 Replies
  • Chris Poisson
    February 22, 2006 at 3:28 pm
  • Jeff Carpenter
    Have you asked your web person what they want? We could spend all day telling you different ways to do this, but if they want something in particular then it doesn’t matter what we say.
    If they have something in mind we can tell you how to do that. Or if they don’t have something in mind, can they at least tell you any specifications they’re looking for?
    Also, what resolution are you starting with?
  • Andrew Wise
    February 22, 2006 at 3:42 pm
    I talked with the web person once. They really don’t know what to ask me for. They have not done alot in terms of incorporating video into a website….so it’s a new area for both of us. I was hoping for an easy way to convert the project (from FCP) that would work well in most cases.
    thanks, -Andrew
  • Jeff Carpenter
    February 22, 2006 at 3:50 pm
    The article Chris posted is probably the best place to start.
    Outside of that, something like the H.263 codec might be good. It would require the view to have Quick Time, but it could use older versions.
    Who are the viewers of this audience? If it’s media-savy people, requiring QT is fine. Heck, if the target is media pros you can probably use H.264 which requires the viewer to have QT 7.
    If it’s a web site aimed at kids, or something, then you’d want something more universal. Maybe even Flash. It depends on how much you expect of your visitors.
  • Craig Seeman
    February 22, 2006 at 5:06 pm
    There’s question one would ask for a job like this.
    Are you or the webmaster going to do the compression?
    W Who is the webpage’s target audience (alluded to in another post)?
    Will it be video/graphics pros?
    Corporate
    Selling a product or service (and what might be the base income bracket of the desired customer)?
    News
    Is the video simply “talking head” or is there significant visual detail?
    I find Quicktime is good for media savvy or artist/musicians
    Window media Video for Corporate or Product/Service marketing (since they may not allow or want Quicktime Player on their systems)
    Broadband data rates for people with some money to spend
    Dial up data rates if it’s very basic news to reach people who don’t spend for broadband connections.
    Data rate may depend on target region(s). Higher broadband data rates for urban areas. Lower broadband for more rural areas where they may be on very slow DSL or Satellite broadband (and even dial up).
    With Quicktime
    H.264 is good for advanced artists or tech savvy (since they need QT 7 and must know to update) and will give you best quality
    Sorenson Pro or MPEG4 for those with older versions of Quicktime.
    Flash is an option but the webmaster needs to know how to integrate.
    Sometimes one may offer two (or more) versions for broadest reach.
    The above are not rules. Just guidelines and only my personal ones at that.
  • Doug Bassett
    February 22, 2006 at 5:11 pm
    I agree with Jeff!
    Either QT or Flash, 5 min of vid is going to take some time and/or be very small.
    This might be a good place to start.
    http://dougbassett.com/andrew.mov
  • Ed Dooley
    February 22, 2006 at 5:14 pm
    As said above, it depends on your audience. If you’re unclear about that, it’s always safe to assume that the
    majority of viewers will be on PCs (like, um, 97% of computer users), unless it’s a totally hip, arty, creative
    crowd. We almost always create a Windows Media version and a QT version for the web, each one optimized
    for the different gamma of each platform. We, on occasion, still do an MPEG-1 version for cross-platform
    compatibility, but more often these days, we’re doing a WMV, QT, and Flash version. That will cover all bases.
    Check out Flip4Mac WMV Studio https://www.flip4mac.com/wmv_upgrades.htm.
    It’s a plug-in that allows you to export to Windows Media 9 files right out of QT apps like FCP,
    QuickTime Pro, Cleaner, etc.
    Ed
  • Doug Bassett
    February 22, 2006 at 5:15 pm
    Craig,
    This is right on the money and I whole heartedly agree with everything but what about our responsibility (for lack of a better term) “or above and beyond duty” to educate our clients no matter the media or medium?
    This is probably way OT but interesting conversation to me non the less.
    Doug
  • David Roth weiss
    February 22, 2006 at 5:26 pm
    Andrew,
    At the risk of making this even more complicated, in addition to what everyone else said, with a 5-minute peice you also need to decide if you will stream the video or simply make it available for download. Streaming starts very quickly and protects your video, downloading can take quite a while and it means giving your video away to all. All of the various video formats have different streaming techniques and considerations.
    DRW
  • Andrew Wise
    February 22, 2006 at 5:48 pm
    Thanks Ed,
    I’m going to look into Flip4Mac. I’ll likely be running into this more & more…. sounds like it may be my best option if I don’t want to pull my hair out (which I don’t)
Page 1 of 3
