Activity › Forums › Adobe After Effects › Export complex 3D interactions as separate render files
  • Export complex 3D interactions as separate render files
    Posted by Alex Ezorsky on March 1, 2013 at 6:11 pm
    I have an animation of a lizard coming out of a sewer hole where the lizard layer is in 3D space and actually comes through the hole of a 3D ground layer.
    I want to be able to export the ground layer as well as the lizard layer in separate elements so that if I want to make changes to the hue of either I can easily do that with an editing program without re-rendering the entire scene.
    The problem is that I cannot seem to turn the ground layer into an effective matte (determining where the bottom of the lizard would be blocked by the ground layer) without losing its 3D capability.
    My gut instinct was to find a way to color overlay the ground layer in the scene so that in the editor I could just to a color key to get rid of it. But of course even the first step of making it a solid color (rather than the textured image that it is) means losing its 3D ability.
    I hope I’ve made my issue clear enough. Annnny suggestions would be supremely appreciated.
    Vishesh Arora replied 13 years, 6 months ago 3 Members · 2 Replies
  • Todd Kopriva
    March 1, 2013 at 9:09 pm
    This script may come in handy:
    https://aescripts.com/rd-render-layers/
    After Effects team blog
  • Vishesh Arora
    March 2, 2013 at 12:14 am
    Alex
    Add-on to Dave’s Advice:
    duplicate your comp. In the duplicate, precomp the two layers
    Open the PreComp_1(Say lizard comp), Go to Composition> Pre-Render. This will automatically send the PreComp to Render Queue with RGB + Alpha Settings. Again follow the same procedure with Precomp_2(Hole comp).
    You can change the Format as by default it is Lossless which results in huge file size.
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    2011 3D Demo Reel:
    https://www.youtube.com/watch?v=lHPgIJU_BR8
