Activity › Forums › Adobe After Effects Expressions › exchange precomps in multiple comps (1500 comps)
Meng Zhiqun replied 4 years, 10 months ago 2 Members · 26 Replies
Meng Zhiqun
November 1, 2021 at 3:17 pmNo worries Gerald, it’s also a learning journey for me!
I’ve edited a V03 script. This time it’s not based on names but selection. In order for the script to run, you need to have layer 0 selected like in the image, before running the script. This script will create a new “MasterComp-Script” Composition and the layers will be compiled there.
You can test this to see if things work, before changing the language to english as that should be quite a hassle.
Fingers crossed! -
Gerald Gutberlet
November 2, 2021 at 7:19 amWorks like a dream, Great script PERFECT Thank you so much you saved me so much Time and feel free to play around with the reaction diffusion if you are into that kind of self organising Systems
Meng Zhiqun
November 2, 2021 at 7:22 amThat’s wonderful Gerald! Your effect looks amazing too and I learned from it as well. I’ve never done effects this way and didn’t know it’s possible. I need to play around with it for sure. 😀
Gerald Gutberlet
November 2, 2021 at 7:34 ami have to give credit to triton2030 his yt chanel inspired me to rebuilt his Template
Gerald Gutberlet
November 2, 2021 at 7:42 amOh and for some reason the master script comp stops at 1000 comps wich is no Problem the script generates the 1500 comps so i just have to sequenze the copms new with AnimationWindow keyframe assistant
Meng Zhiqun
November 2, 2021 at 7:49 amThanks for letting me know! I’m not sure if that’s a problem with scripting tho. I’ve only ever once exceeded more than 1000 layers in after effects in a single comp and when it exceeds 1000, after effects started getting cranky.
