Activity › Forums › Adobe Encore DVD › Encore buttons not showing up
Cael Kuhlman
June 26, 2010 at 1:55 amDitto! I’m running CS5/snow leopard and this solved the problem for the most part as well. Only thing was that some navigation buttons I made were text only and they disappeared on me. So, I’m duplicating those layers so I can have a layer that’s visible always and then a highlight layer with the (=3) name. Otherwise, the only time somebody would see “next page” would be if they landed on that button’s position.
I’m surprised how well this solution worked for everyone and even more surprised that Adobe didn’t fix this yet. I’ve downloaded all their latest updates…
Janice Demille
June 27, 2010 at 9:32 pmI am having a similar problem with Windows 7. I have 20 buttons on the second menu and only 18 of them work. I’ve tried re-creating them and double checked them. Nothing appears different yet in preview and on an actual dvd they do not work.
Any ideas?
thanks
Janice DeMille
Cael Kuhlman
June 28, 2010 at 4:31 pmDVD Studio pro has told me that there is a maximum of 18 buttons allowed on a page. I’m thinking that it’s part of the DVD specifications.
Kingsley Asumadu
November 23, 2010 at 6:08 pmHi guys I know this may be an old thread but I’m dying to get help.
Ok this is my problem, I can’t see highlighted button when I play my project in some dvd players, its not just that, what really kills me is that I’m able to see all button highlights in some players,(newer ones?) also in some players I can only see the highlilighted buttons in the MAIN MENU but when I go into OTHER MENUS from main menu the highlights don’t work, I can see the buttons but not the hilights.THIS IS KILLING ME, PLEASE SOMEBODY HELP.
Worried saul,
Kinksley. -
Brock Gomez
November 24, 2010 at 2:38 amKingsley,
I’ve had a few problems in the past with getting buttons to show up, and the only thing that has worked for me is re-editing the menu in Photoshop with the layer set as (=3). Sometime Encore just bugs out even though I have done the layer setup in Photoshop properly. Earlier this week I burned a DVD that worked fine on the Encore preview, but when burned to DVD the buttons didn’t show up. I went back to Encore, did “Edit Menu in Photoshop”, did EXACTLY what I had done previously and burned again. DVD worked fine. It seems that Encore is just a little weird sometimes. I wish I had a better solution for you…
Brock
Kingsley Asumadu
November 24, 2010 at 4:56 amThanks Brock, I’ve just done what you sudjested, DVD is burning now, I’m keeping my fingers crossed.
This problem has been bugging me for days and I don’t seem to have a solution to it.
I hope your tip helps, I do appreciate your help.
Thanks in advance man.Kingsley.
Kingsley Asumadu
November 24, 2010 at 11:24 pmHi Brock,
Thank you so much for your help, It worked like magic.
I’m excited but not fully because the DVD does not show media content when I open it on my computer.
I have embede folders in the project using DVD-ROM Conentent option.
The weired things I could see them when I had the previous problem, now that is solved I can’t even see the TS files, it say zero kb on dvd even though it play with fully functioning menus.
Do have any idea what mabey causing this?Thanks,
Almost there.Kingsley
Brock Gomez
November 25, 2010 at 12:46 amSorry, but my knowledge is pretty limited. I usually do the trial and error method which seems to have worked in this case. Jeff, who posted above several times, seems to be the go-to guy on all things Encore. Maybe try getting in touch with him?
Brock
Kingsley Asumadu
November 25, 2010 at 4:34 amI got it working, I had some accents and punctuations in the file name and Encore doesnt like and cannot recognise them.
I hope I can use this experience to help someone with similar problem in the future.
I really appreciate your help on my earlier problem.Thanks,
A very happy Kingsley. -
Isabel Dantas dos reis
August 27, 2012 at 10:02 amHi,
After wasting lots of time and energy trying to solve the unsolvable, i came across this forum. It was perfect! It absolutely saved my project and what’s left of my brain. Jeff, thank you so much for your precious help. And thank you all for preceding me in asking my questions and having my doubts!
Thanks!!!
Isabel, Portugal
