Activity Forums Adobe Encore DVD Encore buttons not showing up
  • Encore buttons not showing up
    Posted by Brock Gomez on December 11, 2009 at 9:39 pm
    I have authored and burned a DVD with 2 menus (Main and Chapter Selection) with simple round buttons. The button selection, routing and highlighting works in the Encore CS4 simulator as well as my Mac Pro DVD Player. However, when played on a DVD player hooked up to a SD TV, the buttons either don’t appear at all or a slightly visible outline/interlacing scan appears.
    Any advice on how to get the buttons to show up on a television? I created them in Photoshop CS4 using the methods described here:https://www.videocopilot.net/tutorial/dvd_authoring/ (at the 26 minute mark).
    Thanks for the help!
    -Brock
    Isabel Dantas dos reis replied 14 years ago 12 Members · 30 Replies
  • 30 Replies
  • Jeff Bellune
    December 11, 2009 at 11:42 pm
    Is it the buttons that don’t show up, or the highlights that are missing?
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Brock Gomez
    December 12, 2009 at 1:12 am
    Both the buttons and highlights are not showing up completely. If anything is displayed it is sort of an outline or some scan lines where the button/highlight should be. It sort of looks like the AT&T logo (if that makes any sense). https://www.geardiary.com/wp-content/uploads/2008/09/att-logo.jpg
  • Jeff Bellune
    December 12, 2009 at 3:41 am
    Can you post a screenshot of your menu?
    Is the menu static, or do you have a video background?
    -Jeff
  • Quasi Stellor
    December 12, 2009 at 6:35 pm
    I have the same problem.
    I created 3 menus in Photoshop. Highlights show the names of the items. After burning the DVD, I tested it on a Mac and a PC (progressive screens) and also tested it on a normal old fashion 4:3 tv (interlaced) connected to the mac. Everything works fine.
    When I tested it on the same tv but connected on a DVD player, the menu items (highlights) are unreadable. They look like a interlaced progressive signal (if you understand what I mean) but they look badder than that.
    The problem is with the (=1) & (=2). The (=3) are good.
    (=1) is red, (=2) is black & (=3) is white
    VLC also shows bad the menus
    Here are some print screens:
    How it should look:
    How it’s looking on a TV with DVD player:
    And how it look with VLC:
    You can see in VLC some displacements & some grey areas and they’re are no grey areas in what I made. Only Red, Black & White
    Thx for your time
  • Jeff Bellune
    December 12, 2009 at 8:08 pm
    @quasi,
    Are you using the combination of En CS3 and Leopard? That combo causes highlights to go missing, except that sometimes an (=3) highlight layer will work.
    Reverting to using En CS3 and Tiger is the fix.
    Other than that, I don’t have any idea what’s going on. I’ve never seen that behavior before.
    Sorry I can’t be more help,
    -Jeff
  • Brock Gomez
    December 12, 2009 at 11:42 pm
    The menu is not static. There is an opening animation where the background elements grow and the 3 video panes shown in the screen shot come into place.
    https://vimeo.com/8140161
    The buttons are just simple cirlces that I made in the Photoshop editing technique using the (+) and (=1) expressions.
  • Jeff Bellune
    December 13, 2009 at 1:24 am
    Brock,
    Thanks for posting all of that. I don’t know why you’d see this issue with CS4.
    Can you try setting the (=1) layer names to (=3) layer names and see if that makes any difference?
    And although I don’t think it’s a blank-media-quality issue, if you’re not using Taiyo Yuden or Verbatim blanks you should try one of those brands.
    And if you’re burning at the full rated speed of either the media or the burner, slow it down to 1/2 the rated speed of the slowest one.
    -Jeff
  • Quasi Stellor
    December 13, 2009 at 5:26 am
    Actually I’m using (Snow) Leopard and CS4.
    It’s the first time I’m using Encore to make DVDs. Normally I do then with DVD Studio Pro. Encore promises work flows that aren’t possible in Studio Pro.
    I would like not to have to remake my hole project in DVD Studio Pro because I believe in the potential of Encore.
    Anyway thx for every thing, I really appreciate your commitment,
    quasi
  • Lenny Smith
    December 14, 2009 at 7:59 pm
    i had same problem today of buttons not showing in preview or on burned disc, just to try i went to “edit menu in photoshop” and turned on the eyeballs for the layer highlights, then saved the menu…now preview in encore shows the buttons….have not burned disc yet to see if it’s all ok on a disc. Highlight eyeballs are OFF in the encore layer tab but ON when saved in photoshop…
    Had 5 menus in encore project and they all now show the buttons..Is this not some kind of bug?
  • Nicholas Pollicino
    January 8, 2010 at 9:58 pm
    I too am having the same problem with Encore CS3. I am using OSX 10.6.2 snow leopard. I can my burnt SD dvd flawlessly in Blu-ray players, Computers, Xbox, PS3. However, the button highlights fail to load when playing in a standard DVD player. I’ve tried alternate DVD burners, and changing regional settings. Is there a way to fix this problem without reverting back to an older OSX?? I need leopard in order to use some of my accelerators. Please help if you have the solution
Page 1 of 3
