Activity Forums Adobe Premiere Pro Encoding captions into mpeg2 file.
  • Encoding captions into mpeg2 file.
    Posted by John Watts on January 27, 2023 at 9:25 am
    For the past years I’ve encoded an .mcc file with an mpeg2 for closed captions.
    The old VideoReDo software has worked for this task. However, it won’t complete an encode lately. And it’s seemingly an EOL from quite some time ago.
    I’ve tried generating the .mcc files directly from PPro export. Or have made an .srt file and converted with REV. Neither is working at this point.
    So the obvious question, who is using what? I want an onboard software, no cloud, no online.
    iMac (Retina 5K, 27-inch, Late 2015) Monterrey
    4GHz Quad Core Intel i7
    32 GB 1867 MHz DDR3
    AMD Radeon R9 M395X 4 GB
    PPRO 23.1
    From a grouchy editor at 3:08 in the A.M.
    John Watts replied 3 years, 7 months ago 2 Members · 2 Replies
  • James Brooks
    January 27, 2023 at 2:49 pm
    Hi John
    You can try ccConvert that does that as well. Unfortunately, it is also end of life, but might be enough to do what you need. It will insert the captions as DTV/CC and SMPTE ANC stream from MCC.
    Cheers, James
  • John Watts
    January 27, 2023 at 5:59 pm
    Not an option as an independent software anymore. They’ve become part of a more expensive service. I simply can’t believe it is so hard to find a solution for this.
