Activity Forums Adobe After Effects Expressions EditText Listbox subitem
  • EditText Listbox subitem
    Posted by Scott Mcgee on April 3, 2017 at 3:57 pm
    I have two columns, Column one is to reference my layer, Column two is to reference a value.
    My array will always sequentially go in order, but my value will always change. So I want to include to the expression below. That if I fill out var input = win.add (“edittext”);
    input.active = true;
    it will add it to column two if I hit add item.
    Then say I got the number wrong. I want it to be another value. If I highlight the row. Refill out var input = win.add (“edittext”);
    then hit insert.
    It will update it.
    I’ve seen scripts that just us insert via editText and scripts that use just arrays. I haven’t found an example that allows the two.
    var testArr = [];
    startGUI();
    function startGUI() {
    // Main Window
    var win = new Window( “palette”, “Test Listbox”, undefined, { resizeable:true } );
    win.orientation = “column”;
    win.alignChildren = [“fill”, “fill”];
    // Listbox Group
    var grpListbox = win.add(‘group’);
    grpListbox.alignChildren = [‘fill’, ‘fill’];
    var myListbox = addListBox (grpListbox, testArr);
    // add ListBox
    function addListBox(container, testArr) {
    var listbox = container.add(“listbox”, undefined, testArr,
    numberOfColumns: 2,
    showHeaders: true,
    columnTitles: [‘Bar’, ‘Value’]
    return listbox;
    var b = win.add (“button”, undefined, “Insert”, {name: “ok”});
    // BTN: Add Items To Array
    var addItem = win.add(“button”, undefined, “Add Item”);
    addItem.onClick = function() {
    testArr.push (‘Bar’ + ” ” + (testArr.length + 1));
    grpListbox.remove(grpListbox.children[0]);
    win.layout.layout(true);
    //updateListboxArray(myListbox);
    //$.writeln (testArr.length + ” ” + myListbox.items.length);
    // BTN: Clear Listbox
    var removeAllItems = win.add(“button”, undefined, “Clear Listbox”);
    removeAllItems.onClick = function() {
    // Clear the array
    testArr = [];
    // Update listbox items
    function updateListboxArray(listbox) {
    // Clear listbox first
    listbox.removeAll();
    // Create new listbox items from array
    var i = 0;
    while (listbox.items.length < testArr.length) { listbox.add (“item”, testArr[i]); i++;}
    // Quit BTN
    win.quitBtn = win.add(“button”, undefined, “Close”);
    win.quitBtn.onClick = function() {
    win.close();
    // Window Settings
    win.onResizing = function () { this.layout.resize(); };
    win.onShow = function () { win.layout.resize(); };
    win.center();
    win.show();
    Scott Mcgee replied 9 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
