Activity › Forums › Apple Final Cut Pro Legacy › Edit to tape makes me render
Posted by Mike Kahn on April 25, 2008 at 7:06 pmI am trying to write a Prores 422 (HQ) sequence to HDCAM tape and it’s making me render every time. Is there a setting I can change to make this stop? I have everything rendered in the timeline and it’s taking an hour to render.
Any ideas? As always, I’m under time constraints.
MikeJohn O’neil replied 17 years, 6 months ago 11 Members · 24 Replies -
Mike Kahn
April 25, 2008 at 7:09 pmThere are no disabled clips. I have a textless sequence and all the text above it nested with a broadcast safe filter on it.
Jeremy Garchow
April 25, 2008 at 7:14 pm[Mike Kahn] “I have a textless sequence and all the text above it nested with a broadcast safe filter on it.”
Is that rendered fully?
Shane Ross
April 25, 2008 at 7:15 pmAnd by that he means, no DARK GREEN either…but either grey or fully rendered purple.
Shane
GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
http://www.LFHD.net
Read my blog! -
Mike Kahn
April 25, 2008 at 7:16 pmYes everything is totally rendered, it took an hour to do it right before I tried to lay it off.
David Bogie
April 25, 2008 at 7:18 pmI’ve never used that codec but edit to tape always does this rendering thing; it’s a stupid non-feature that has been around forever. (You may be looking at a different issue, dunno for sure.) We used to solve it two ways. Export the sequence as a self-contained movie, reimport it, put it in a fresh sequence, print the sequence. It should not require rendering. Or, since most of us do not have t/c or frame accurate editing on our little DV decks, we put the machine into record and push play on the timeline. You build your timline with bars, tone, slates, countdaowns included instead of using the edit to tape interface. It’s the ETT and PTT interfaces that cause the entire project to render every time you try to do the edit.
bogiesan
Jeremy Garchow
April 25, 2008 at 7:18 pmAre you absolutely sure there are no disabled clips in the timeline? Even one clip will mess it up.
Mike Kahn
April 25, 2008 at 7:19 pmYes it’s a big quicktime and all my titles. There is nothing disabled.
Mike Kahn
April 25, 2008 at 7:28 pmYeah I think I’m going to have to render out my titles and lay them back in. I was hoping not to have to do that but I’ll take the hour once rather then every time I have to make a layback.
Thanks.
Mike -
Jeremy Garchow
April 25, 2008 at 7:33 pmAnd you are dragging the timeline from the browser to the ETT window?
For what it’s worth, I never have to do this render step unless a clip is disabled in the timeline.
Opposite of what Bogie says, but true for me.
