Activity Forums Apple Final Cut Pro Legacy Edit to tape makes me render
  • Mike Kahn
    April 25, 2008 at 7:36 pm
    I am dragging the sequence from my browser window into the ETT window.
  • Jeremy Garchow
    April 25, 2008 at 8:34 pm
    Must have something to do with that nest.
    Jeremy
  • Chris Poisson
    April 25, 2008 at 8:40 pm
    I have NEVER had to render on Edit to Tape, Print to Video, yes, but not ETT. 99% of my timelines are 8 bit uncompressed going to Beta SP, perhaps that is a factor, but never had to render, even with extra clips in the timeline.
    But, yesterday I did have a strange behavior with ETT, it was all working fine but I got no video on the tape, only audio. Ended up having to make my dubs on the fly. Dunno, never seen that before.
    Have a wonderful day.
  • John Christie
    April 25, 2008 at 8:55 pm
    Make sure you have no empty tracks in you sequence. IE: if you have video on Track 1, make sure your titles on track 2. I don’t know when I discovered this, but it always works for us. For some reason when FCP sees an empty track it needs to render the information above that track.
    Cheers
    John Christie
  • Bob Flood
    April 25, 2008 at 10:47 pm
    Mike
    what happens if you switch off the record to tape high quality ie under the RT tab on the timline, there is a selector for Record to tape. Set it to “use playback settings”
    if you still have to render, then try switching the playback from safe to unlimited but high quality
    the next thing to do would be to change your timline settings to match the format of video you are putting out IE forget the Pro Rez and set the timeline for 1080i at waht ever frame rate
    (it sounds like FCP does not think your timeline is “native” enough, hence the rendering)
    hope this helps
    hope this helps
    “I like video because its so fast!”
    Bob Flood
    Greer & Associates, Inc.
  • Lance Bachelder
    April 25, 2008 at 11:30 pm
    You’ll always have to render the broadcast filter 1st. Are you rendering during Edit to Tape?
    Make sure you render 1st – save – so you don’t lose your render for future – then go into edit to tape.
    Lance Bachelder
    Southern California
  • David Bogie
    April 28, 2008 at 1:44 pm
    [Jeremy Garchow] “For what it’s worth, I never have to do this render step unless a clip is disabled in the timeline.
    Opposite of what Bogie says, but true for me.”
    You know, come to think of it, I cannot recall using any of these processes in years, probably not since v4.5. I should have checked my system first.
    bogiesan
  • Mike Kahn
    April 28, 2008 at 4:05 pm
    I spoke with a friend and he told me that nests and ETT do not get along. I had two options, I could unnest everything and rerender or I could export as a self contained animation with an alpha since they were titles. I went with unnesting and rerendering since it was only a broadcast safe filter that I was trying to apply.
    Mike
  • Jeremy Garchow
    April 28, 2008 at 4:08 pm
    Did it work for you? You can copy and paste the broadcast safe filter on all the clips you need to without nesting.
  • Mike Kahn
    April 28, 2008 at 4:16 pm
    I know I can apply it to all my titles but some had transition effects on them that needed the broadcast safe filter on it as well. For this show I didn’t have that but in the future I might and I’ll have to make it an animation with an alpha channel and render.
Page 2 of 3
