Activity Forums Adobe Premiere Pro Edit In Low Quality – Export With High Quality
  • Edit In Low Quality – Export With High Quality
    Posted by Pmcgoohan on October 11, 2007 at 5:12 pm
    Hello,
    I’m new to Premier Pro, and video editing in general, so apologies if this has already been discussed but I can’t find it if it has.
    I was wondering if it is possible to edit using small/low quality versions (eg: DivX) of large/high quality (eg: DV) files, but then swap the high quality files back in when I do the final export.
    This would keep my poor clapped out old PC responsive during the edit, but not compromise on the final quality of the movie.
    I know there is a Replace With Clip function, but really I want to replace at file level, plus I think the clips have to be the same standard to use the replace function.
    I’d be very grateful for any help on this.
    Cheers.
    pmcgoohan
    Darren Edwards replied 18 years, 11 months ago 4 Members · 8 Replies
  • 8 Replies
  • Marc Brak
    October 12, 2007 at 6:42 am
    The best help anyone can give you on this is really: don’t do it. Divx wasn’t designed for editing, nor were mpeg, wmv or any other distribution format. So it just won’t work properly, if at all. Just go with DV Avi.
    By the way, i’ve worked with premiere on some pretty worn down pc’s (including my current one), and as long as you save regularly, you should be ok 🙂
  • Pmcgoohan
    October 12, 2007 at 9:00 am
    Thanks, thats encouraging- and my PC isn’t so bad!
    While I do understand that editing with compressed formats might not be a good idea, what about working with low quality uncompressed versions (eg: 200×150 uncompressed AVI).
    Wouldn’t that make for a more fluid editing experience? Or is it too difficult to swap source files like this in Premier Pro anway?
  • Mike Velte
    October 12, 2007 at 12:03 pm
    Windows XP, Premiere Pro and Intel/AMD have all collaborated over the years to make editing DV easy on a PC. Editing Highly compressed or small resolution source material will be problematic. Go with the flow.
  • Darren Edwards
    October 12, 2007 at 12:29 pm
    Mr Goohan,
    What you’re describing is the offline-online process, and
    PPro is as good as any other edit-suite for it. As Adobe
    were quick to point out, some of the rushes from the last
    Superman film were ingested into PPro for offline editing.
    There is a little bit of studying to do, though, before you
    get started, because, to understand offline-online, you also
    need to understand Timecode (TCR), Edit Decision List (EDL)
    and, eventually, Batch Capturing.
    PPro’s Help is stacked with info. Open Help and do a Search
    for ‘Offline’ and ‘EDL’. What you’ll learn there will stand
    you in good stead for any pro edit-suite in the future.
    Darren.
    x-gf.com
  • Pmcgoohan
    October 12, 2007 at 12:39 pm
    Thank you, that was just what I was looking for.
    I will start by editing the raw DV files, which will be MXF’s from a Panasonic HVX200, so I hope the promised MXF update comes out soon- and works!
    If that proves too slow, its good to know I’ve got the option to do the offline-online process in PP.
  • Darren Edwards
    October 12, 2007 at 12:44 pm
    Which version of PPro are you using, by the way, because the
    ‘offline’ info available upto ver. 1.5. is not particularly
    useful; you tend to go around and around in circles when
    reading it.
    D.
    x-gf.com
  • Pmcgoohan
    October 12, 2007 at 12:50 pm
    I’m using CS3, so hopefully the documentation will be clear enough.
    It helps just knowing what the process is called!
  • Darren Edwards
    October 12, 2007 at 12:58 pm
    ‘Online’ is universally thought of as the process of bringing
    everything together and/or replacing footage etc for the final
    edit, but there’s another definition of ‘online’ too – used by
    friends of mine at the BBC, anyway.
    An online editor is also someone responsible for pulling
    together replys and montage sequences etc. which are quickly
    required during, for example, a live sports program. In the
    BBC’s case, usually on a Quantel suite.
    Learning off-/online is now mandatory with HDV becoming
    affordable. Although, media/asset management – which
    is what it is all about, really (film, music, CG,
    HD) – is evolving quite quickly, and affordable
    render farms will also change the face of off-/online.
    D.
    x-gf.com
