Activity › Forums › Apple Final Cut Pro Legacy › DVCPro HD monitoring questions…
Posted by E. Eric johnson iii on July 13, 2006 at 9:02 pmhello friends in the pasture…
right now i’m working on my first project in DVCPro HD. i need a client type monitor (i can’t afford what’s needed for HD critical CC) so i can see an output version other than what’s in my edit windows. the plan is to take the final output and do the CC out of house to complete the project.
so the questions are:
what kind of video card would you recommend? (i have an Nvidia 6800 now)
what’s a good, inexpensive monitor to serve this purpose? (i’m using an Aja Io-LA for SD monitoring)
any other alternatives you can think of?
thanks for your help,
e3
e. eric johnson iii
eric@lillcreates.com
lill creates: founder/executive producer
Water Channel: producer/virtual set operatorE. Eric johnson iii replied 20 years, 1 month ago 5 Members · 13 Replies -
Jeremy Garchow
July 13, 2006 at 9:30 pmIf I were you I would take that money that you are going to spend for an online and buy yourself an AJA Kona series card and A Sony PVM 14L5/1.
Walter Biscardi
July 13, 2006 at 9:38 pm[WaterBoy] ”
what kind of video card would you recommend? (i have an Nvidia 6800 now)”This is your graphics display card, not a video monitoring card. You want one of the AJA Kona series cards.
[WaterBoy] “i need a client type monitor (i can’t afford what’s needed for HD critical CC) so i can see an output version other than what’s in my edit windows. the plan is to take the final output and do the CC out of house to complete the project.”
An HD critical monitor is only $1,600 for the Sony PVM14L5/1. That’s probably a savings over going out of house to CC. You can CC yourself and finish the project in house.
Walter Biscardi, Jr.
https://www.biscardicreative.com“I reject your reality and substitute my own!” – Adam Savage, Mythbusters
E. Eric johnson iii
July 13, 2006 at 9:56 pmi guess it’s time to suck it up and buy the PVM/KONA deal…
thank you and glory to the cow.
e3
Shane Ross
July 13, 2006 at 10:36 pmJust for client monitoring I use Digital Cinema Preview on my second monitor…looks great.
But for critical color correction…I just bought the PVM-14L5. Popular monitor that.
Shane
Alokut Productions
http://www.lfhd.net -
Tom Matthies
July 14, 2006 at 1:46 pmI’m in the process of building a small HD suite right now. For client monitoring, I’ve decided to go with the Kona3 board in a Quad G5, an Aja HDP to convert the HD-SDI data stream from the Kona to DVI and then to a Dell 24″ wide screen LCD monitor for the client desk. The Dell arrived a few days ago. The Aja equipment was shipped yesterday. With a little luck I’ll let you know how it works in a few days.
I will be checking into the Sony PVM-14L5 however. It seems to be a popular choice here. 🙂
Tom -
Walter Biscardi
July 14, 2006 at 1:58 pm[Tom Matthies] “I will be checking into the Sony PVM-14L5 however. It seems to be a popular choice here. :)”
For color correction, it’s still the monitor to go with.
for the client, we run a 50″ Panasonic Plasma because it can display the colors almost identically as the Sony. I didn’t go with a computer LCD screen because I haven’t found one that can close replicate the Sony excecpt the Apple Displays. But even there, I find it easier to hang the monitor on the wall and give the client some distance from it.
Tom Matthies
July 14, 2006 at 4:57 pmJeez Walter.
I’m embarassed to say this. I actually HAVE this monitor sitting on my edit desk right now. I just don’t have any of the digital input cards for it.
And, you know, for some reason I thought this model number sounded familiar…
DOH!
Tom -
Jeremy Garchow
July 14, 2006 at 5:05 pmSave your money and don’t buy a digital input card for it. Get a Kona 2/3 (only digital ins and has upconversion) or perhaps a Kona LH/LHe (analog inputs and no upconversion) and use the analog component inputs of the monitor. You are good to go.
Jeremy
E. Eric johnson iii
July 14, 2006 at 9:34 pmTom-
please let me know how you system setup goes. i would love to hear your reviews & thoughts.
e3
E. Eric johnson iii
July 14, 2006 at 9:41 pmjeremy-
so instead of getting the monitor card/board, i could just put the $ toward the kona 2 card (i’m running a dual 2.5) and hopefully save some money. but would this effect my critical color correction?
e3
