Activity › Forums › Apple Final Cut Pro Legacy › DVCPro HD monitoring questions…
E. Eric johnson iii replied 20 years, 1 month ago 5 Members · 13 Replies
Jeremy Garchow
July 14, 2006 at 11:45 pmSorry, Waterboy, I was talking to Tom who said he had a PVM already.
You need to get a PVM14L5/1 and a Kona 2. Hook up the Kona 2 analog component output to the analog component inputs of the PVM. The analog component inputs are auto sensing analog HD and SD. You will be great for cc. That’s all you will need. You can bring in analog SD material through your io LA. The Kona 2 and LA work great together on the same machine.
Sorry about the cornfusion.
Jeremy
E. Eric johnson iii
July 19, 2006 at 3:30 amthank you to all…
i sucked it up (or drained my savings) and went with the KONA 2 & PVM 14. it sounds like the durability of the PVM and it’s multi-format capabilities will match my various needs for years to come.
again thank you @ glory to the cow!
e3
