Activity Forums Adobe Premiere Pro DV Timeline
  • DV Timeline
    Posted by Prochris on October 9, 2006 at 2:55 pm
    Hey all at Creative Cow
    I’ve been having a problem capturing from a Panasonic mini-DV camcorder.
    Well, it captures fine, but I’m working between a laptop and a pc, only one of which has enough capturing and editing power, so I’m going the batch capturing route. The problem is that, when I scan through the camera to find the IN and OUT points for each clip, the tape’s timeline sometimes starts back from zero, or even some other random number (all 7 of the tapes have this problem). As I’m sure you can imagine, this makes entering the IN and OUT points into PP2 impossible, as if there are two 00:12:15:24 for instance, it will always choose the first one, because it’s the only ‘official’ one. I’ve heard from some old posts on this forum, that there is a way to fix it by using the ‘blank run’ option in the menu, but this didn’t do anything.
    If anyone could help me with this problem I’d be really grateful.
    Thanks, Chris
    I’m lost…
    Blast1 replied 19 years, 11 months ago 2 Members · 3 Replies
  • Blast1
    October 9, 2006 at 6:37 pm
    To make sure you have continous time code when you stop, start, turn off, unload/reload tape, is to overshoot each clip by a few seconds, then monitor the tape TC when you turn the cam on or continue the shoot, if it says “0” go into the VCR mode and position the tape a slight bit into the previous clip, TC in consumer DV cams always starts at “0” if there is a break or uses the TC from the last read frame before new recording.
    A way to get continous TC from the fragmented tapes is to a dub to another camcorder and make a copy, it will have continous TC.
  • Prochris
    October 10, 2006 at 1:31 pm
    Thanks for that
    But sadly I don’t currently have access to another camcorder, so for now I can’t do that. Do you, or does anyone else know of any way (apart from the one mentioned above) to fix a broken timeline? Surely there must be a program or an option in Premiere?
    Any and all help is greatly appreciated, as this could save me a lot of time and trouble (and money), that could be put to much better use.
    Thanks again, Chris
    I’m lost…
  • Blast1
    October 10, 2006 at 6:37 pm
    If you capture all the clips on a tape and put them on the timeline in order and export back to tape the timecode will be continous.
