Activity Forums DaVinci Resolve Dual-link SDI 4:4:4 – external scopes?
  • Dual-link SDI 4:4:4 – external scopes?
    Posted by Ola Haldor voll on November 10, 2011 at 9:44 am
    I’ve received a brand new monitor to test, and I’d like to check 4:4:4 – but how would I route cables in order to feed the Decklink HD Extreme (version 1 I believe) I have in Mac #2 with ScopeBox? It doesn’t have two inputs as far as I know.
    Margus Voll replied 14 years, 9 months ago 4 Members · 23 Replies
  • 23 Replies
  • Margus Voll
    November 10, 2011 at 10:45 am
    most “cheap” scopes are 422 anyway.
    Margus
    https://iconstudios.eu
  • Ola Haldor voll
    November 10, 2011 at 11:21 am
    Hmm.. I think I would need either a new Decklink or the UltraScope anyway. I can’t feed the old Decklink HD Extreme with 25p, but must use 25psF out from Resolve. Pity!
  • Margus Voll
    November 10, 2011 at 11:26 am
    look at those specs. i think ultrascope is also 422
    Margus
  • Ola Haldor voll
    November 10, 2011 at 12:08 pm
    Hmmm… So how should I do it then? Buy a billion dollar hardware box?
    Gotta get this episode out of the system before I start dissecting the possibilities of the monitor I guess.
  • Margus Voll
    November 10, 2011 at 1:33 pm
    i’m not sure there is point ?
    444 gives you more resolution in scope with but hi and low should be the same in vertical?
    Margus
  • Ola Haldor voll
    November 10, 2011 at 1:43 pm
    My point is: If I use the two SDI outputs on the Decklink to feed the monitor with Dual-link HD-SDI, I need some way to send the signal to the other Mac which makes the scopes.
  • Margus Voll
    November 10, 2011 at 1:46 pm
    Scope with bypass or splitter before monitor.
    Should be doable.
    Margus
  • Ola Haldor voll
    November 10, 2011 at 1:47 pm
    Anyone at BMD care to chip in with an advise?
  • Margus Voll
    November 10, 2011 at 1:49 pm
    Monitor does not have loop?
    Margus
  • Margus Voll
    November 10, 2011 at 1:53 pm
    Or 3G maybe?
    Margus
Page 1 of 3
