Activity › Forums › DaVinci Resolve › Dual-link SDI 4:4:4 – external scopes?
  • Ola Haldor voll
    November 10, 2011 at 2:02 pm
    It has loop through. But I’m not sure ScopeBox support dual-link, nor do I have two SDI inputs on that Decklink.
    The monitor support 3G, have yet to figure out how to make it show correct colors.
  • Margus Voll
    November 10, 2011 at 2:05 pm
    i would go with ultrascope then.
    1 3g to monitor one to ultrascope.
    Margus
    https://iconstudios.eu
  • Kevin Cannon
    November 10, 2011 at 2:40 pm
    Although the Ultrascope supports 3G, it doesn’t support 444 RGB over 3G. it only uses 3G for 422 at higher frame rates. I’m sort of stuck in the same position… there isn’t a great and inexpensive option for 2K resolution or 444 RGB scopes… I could use a 2K > 1080p scaler to deal with the ultrascope being limited to 1080p, but the 444 is a little harder to sort out.
    KC
    Prehistoric Digital
    PhD Grading Suite
  • Ola Haldor voll
    November 10, 2011 at 3:04 pm
    Ok, somewhat good news. My friend Leo chimed in to say “loop through with one of the channels should work”. All though I’ve populated the scopes with pixels, I’m not completely sure it’s correct, since the input is only showing “half the image”.
    But at least I can check the luma.
  • Margus Voll
    November 10, 2011 at 3:20 pm
    3g is not half the image ? it just has less resolution in color steps ?
    even with 422.
    Margus
  • Ola Haldor voll
    November 10, 2011 at 3:25 pm
    Sorry for being unclear. I’m on dual-link 4:4:4 now. The other card won’t go with 3G.
    Nevermind my previous post. I’m not making sense now. Too tired from an already too long day (even though it’s not even 5!)
    We gotta find a way to figure this one out, guys. 🙂
  • Robert Houllahan
    November 10, 2011 at 3:58 pm
    How about the internal Resolve scopes? I believe they are 4:4:4 and just the cost of a second monitor. Otherwise there are a number of actual 4:4:4 scope solutions but I think some sticker shock applies..;-)
    https://www.omnitek.tv/products/video-test-measurement/xr.html
    I think that one is around $10k…
    I was using Ultrascope but stopped using it and put a second display on Resolve for the feature I recently graded and find the internal scopes to be ok…
    -Rob-
    Robert Houllahan
    Director / Colorist
    Cinelab Inc.
    http://www.cinelab.com
    MAHC-PRO 6-Core 3X GTX285 20Tb SAS Wave Panel Panny 11UK SDI Plasma.
  • Margus Voll
    November 10, 2011 at 4:30 pm
    do you have ultrascope still ? i’m going to get one soon.
    Btw. Ola i just ended 36 h shift so you can not be tiered 🙂
    Margus
  • Robert Houllahan
    November 10, 2011 at 4:52 pm
    I still have the Ultrascope and have put it on a telecine suite. I think is is a good basic 4:2:2 scope but it is not everything I would want in a scope for DI work.
    Maybe BMD will eventually get around to doing a software update, hopefully after looking at some other hi end scope solutions.
    The hardware supports 3G in which makes me wonder if it could eventually become a 4:4:4 capable scope.
    -Rob-
    Robert Houllahan
    Director / Colorist
    Cinelab Inc.
  • Ola Haldor voll
    November 10, 2011 at 6:30 pm
    Unfortunately, to my experience that comes with a cost: performance.
Page 2 of 3
