Activity › Forums › AJA Video Systems › Dual HD-SDI in to a Kona 3, from two XDCAM EX1’s, for on set capture/playback/edit
Posted by Pierre on January 27, 2008 at 8:09 pmCurious, has anyone done something similar to the below scenario. Will this work ?
I’ve got a shoot coming up and I’m considering the XDCAM EX1.
The director has asked if it’s possible to do a quick assembly on set.
Is it possible to bring two simultaneous streams of XDCAM EX1 HD-SD1 into Final Cut Pro via a Kona 3 card (capturing as DVCPRO-HD ) ? I’ve got a 5 bay esata raid by KONA (fast enough)?
The director wants:
1. Instant playback (We should be able to get this directly from FCP bin after capture, right?)
2. Rough assembly of two cameras within a couple minutes of the footage being shot.
Also, a little off subject… but I’m wondering if I can record media to the EX1’s express cards WHILE recording to disk?
Michael
Ramona Howard replied 18 years, 7 months ago 9 Members · 29 Replies -
Jeremy Garchow
January 27, 2008 at 10:36 pm[Michael Pierre] “Is it possible to bring two simultaneous streams of XDCAM EX1 HD-SD1 into Final Cut Pro via a Kona 3 card (capturing as DVCPRO-HD ) ? I’ve got a 5 bay esata raid by KONA (fast enough)?”
Not in its current iteration, no.
[Michael Pierre] “1. Instant playback (We should be able to get this directly from FCP bin after capture, right?) “
From one camera, yes.
[Michael Pierre] “. Rough assembly of two cameras within a couple minutes of the footage being shot. “
You could record one of them via FCP and transfer the card of the other and assemble that way.
[Michael Pierre] “Also, a little off subject… but I’m wondering if I can record media to the EX1’s express cards WHILE recording to disk? “
Yes.
Mathieu Marano
January 27, 2008 at 11:52 pmBut is it possible to capture a Dual Stream from the SRW1 with a Kona 3?
Mathieu Marano
online editor – motion graphics – Post-prod director
Directeur technique de post-production
Le Bureau de post productionAdministrator of the Montreal Final Cut User Group
http://www.finalcutmtl.org -
Pierre
January 28, 2008 at 12:05 amMatthew wrote: “But is it possible to capture a Dual Stream from the SRW1 with a Kona 3? ”
Yes this confuses me… I thought “dual hd-sdi” was possible with the Kona card 3. If possible from a SR-1 deck than why not in other ways?
Is there a work around for this?
Taking the card out of the camera, transferring it and unwrapping it takes to much time and defeats the idea of having “instant playback & edit”.
How is this possible? A wafian ?
Jeremy Garchow
January 28, 2008 at 12:05 amDual link from one camera, yes. Two separate streams of video, no. Not with the ‘stock’ AJA software.
Pierre
January 28, 2008 at 12:07 amDo you have knowledge of “non-stock” AJA software that makes capture from two HD-SDI sources possible?
Jeremy Garchow
January 28, 2008 at 12:08 amDual link HD SDI is totally different than recording two separate streams of video.
Dual link HD SDI is combined from one source and creates one video file, you want to take two sources and record two separate video streams.
Jeremy Garchow
January 28, 2008 at 12:28 amYou’d have to talk to a company that writes their own drivers, like the RaveHD folks.
It is far from cheap.
Pierre
January 28, 2008 at 12:36 amThis is totally crazy and I’m sure it wouldn’t work… but, what if I had two separate Kona 3 cards installed into the same computer?
Would the computer recognize the two separate cards?
Even if I could do this I guess final cut pro is only capable of capturing 1 stream at a time… but it can play back several at the same time. Seems like these two things (capture and playback) are very similar… at least in terms of data rate.
I guess it’s a software limitation… as you said.
Walter Biscardi
January 28, 2008 at 12:48 am[Michael Pierre] “Is it possible to bring two simultaneous streams of XDCAM EX1 HD-SD1 into Final Cut Pro via a Kona 3 card (capturing as DVCPRO-HD ) ? I’ve got a 5 bay esata raid by KONA (fast enough)?”
Nope. FCP can only accept one video input at any one time for capture.
Also, Dual Link HD-SDI is the combining of both HD-SDI inputs into one video signal such as 4:4:4 HD.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR
The new Color Training DVD now available from the Creative Cow! -
Mathieu Marano
January 28, 2008 at 1:24 amI was talking about Dual Stream HD and not dual link. DUal Stream is the possibility to record 1080i 4:2:2 to the HDCAM SR recorder SRW1. It it used to record stereoscopic images for 3D but it can be used tu record two completly different camera.
I’ll start another thread for that…
Mathieu Marano
