Activity › Forums › AJA Video Systems › Dual HD-SDI in to a Kona 3, from two XDCAM EX1’s, for on set capture/playback/edit
Ramona Howard replied 18 years, 7 months ago 9 Members · 29 Replies
Bob Zelin
January 28, 2008 at 2:40 amMichael,
this is the answer to your question, since you are so persistant (“but it has to work, there must be a way”) –this is the answer –
NO
NO
NO
NO
NO
NO, and in case I am not clear about this –
NO you CANNOT RECORD TWO DIFFENT SIGNALS ON THE SAME COMPUTER AT THE SAME TIME from ANY CAPTURE CARD for FCP or PREMIER.Talk to SpectSoft (Ramona).
Bob Zelin
Jeremy Garchow
January 28, 2008 at 3:48 am[Mathieu Marano] “I was talking about Dual Stream HD and not dual link. DUal Stream is the possibility to record 1080i 4:2:2 to the HDCAM SR recorder SRW1. It it used to record stereoscopic images for 3D but it can be used tu record two completly different camera. “
Nope, sorry man. That’s the same thing. Two separate video streams.
The Kona will record dual link in it’s “downloadable” out of the box configuration, it will not record dual stream in it’s out of the box config.
Jeremy
PS Nevermind, Bob said it better.
Nick Righton
January 28, 2008 at 4:58 amYou could do a live mix with something like the panasonic AV-HS400N HD-SDI mixer. Run HDSDI out of both cameras into the mixer and out into the Kona. Another option would be to run HDV out of both camera’s via firewire and use Big Mugs Capture HD https://www.bigmugsoftware.com/capture/ software that will allow you to capture multiple HDV / DVCPROHD sources at once. I have not used either so I can not vouch for either one.
I wish I was good at one thing rather than average at many, but oh well.
Gary Adcock
January 28, 2008 at 1:23 pm[Mathieu Marano] “But is it possible to capture a Dual Stream from the SRW1 with a Kona 3? “
Dual Link HDSDI and Dual Stream are 2 completely different things
Dual Link Video requires that the video be distributed as 4:2:2 and 0:2:2 signals over a bonded HDSDI pair.
Dual Stream is a Mode available on very few SRW1 decks that have been enabled for Stereo (3D) acquisition.
mac based editing platform do not currently have the capability to acquire as Dual Steam.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Inside look at the IoHD -
Gary Adcock
January 28, 2008 at 1:26 pm[Michael Pierre] ” but, what if I had two separate Kona 3 cards installed into the same computer?
Would the computer recognize the two separate cards? “NO.
This is an OS level issue and not something that can be controlled by the aja software.gary adcock
Studio37
Ramona Howard
January 28, 2008 at 5:07 pmInexpensive 🙂
When you consider your getting 2 SR’s on steroids in one box, 36K is a drop in the bucket….in fact that’s less that most cheap decks on the market.
Seriously.
There are many things possible with this hardware but it takes the synergy of the Hardware, OS and the app to make it all work and to work well , we are lucky enough to get to write for all of the above, getting us far more than the next guy. Not writing for the masses helps (every joe who owns a video camera). RaveHD is written for professionals and to address the workflow needs of that environment.
Dual SDI as in Dual Link is not the same as (Dual independent streams of SDI) in regards to how the AJA boards handle them or how the info is passed down the SDI wire. Our app and driver was written to handle dual streams in a manner that we can do both. We wrote the RaveHD app to adjust for these type of changes. The industry never sits still so we wrote our app to adapt.
Watch for info on our Quad, HD system, now that’s a hard one to wrap your head around 🙂
Cheers,
Ramona -
Pierre
January 28, 2008 at 5:22 pmNick.
That Big Mug Software is a great idea. I don’t know why Apple doesn’t make it possible to capture more than one stream at a time. Seems like is would be relatively easy to do… I mean if you can get multiple streams of DVCPROHD through firewire via “big mug” than why can’t apple do it with Kona/HD-SDI.
Gary Adcock
January 28, 2008 at 6:12 pm[Michael Pierre] “Seems like is would be relatively easy to do… I mean if you can get multiple streams of DVCPROHD through firewire via “big mug” than why can’t apple do it with Kona/HD-SDI.”
your kidding right?
handling 2 streams of DATA ( thats all FW is) is a simple issue for any computer compared to handling 2 HD steams of baseband video.
gary adcock
Studio37
Pierre
January 28, 2008 at 6:26 pmsorry, I’m not kidding. Just curious and I guess I don’t fully understand what the difference is. I’m learning, and admit that I’m not always aware of what I don’t even know.
Please go easy.DVCPROHD is DVCPROHD, 100 mbps. data right?
I don’t understand why it would be any different to capture two streams of DVCPRO-HD (or what ever flavor) direct to disk via firewire vs. HD-SDI. If this software https://www.bigmugsoftware.com/capture/ can do it with firewire (small bandwidth capability in comparison to HD-SDI) than why can’t Final Cut with Kona/HDSDI ?
There is something I’m missing.
