Activity Forums Apple Final Cut Pro Legacy DROPPED FRAMES help
  • DROPPED FRAMES help
    Posted by Rip Swan on April 2, 2009 at 10:38 pm
    I’m working on a sort of promotional video for the local library in FCP 6. I’ve got a couple of time lapse clips I recorded using Interval Recording on my camera. So I’ve imported the clips alright and they play alright in normal speed, but when I bring their speeds up to around 2,000 – 5,000%, it won’t play the whole clip (which is now about 3-5 seconds). It drops frames every time with the following error message:
    RT Extreme has determined these dropped frames were caused by slow disks. Please try:
    -Increasing the speed of your disks.
    -Decreasing the number of RT layers.
    -Limiting your RT bandwidth in User Preferences.
    Can anyone help. Are these actual solutions and if so how do I do these things?!?!
    Thanks a lot
    Sean Oneil replied 17 years, 4 months ago 7 Members · 13 Replies
  • 13 Replies
  • Walter Biscardi
    April 2, 2009 at 11:14 pm
    What hard drive array are you using. Certainly not your internal Mac HD.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • Rip Swan
    April 2, 2009 at 11:46 pm
    I’m using an external “iomega” 320 Gb hard drive. I’m saving everything (render, capture, etc.) onto it.
  • Walter Biscardi
    April 3, 2009 at 12:22 am
    [Rip Swan] “I’m using an external “iomega” 320 Gb hard drive. I’m saving everything (render, capture, etc.) onto it.”
    USB? Firewire? Firewire 800?
    Read my Blog!
  • Rip Swan
    April 3, 2009 at 1:33 am
    USB. And the hard drive needs to plug into the wall, not simply run off the computer
  • Walter Biscardi
    April 3, 2009 at 1:38 am
    [Rip Swan] “USB. And the hard drive needs to plug into the wall, not simply run off the computer”
    There’s your problem. USB drives are not recommended in any way, shape or form for video editing. They cannot provide the sustained throughput for video editing. FW400 is the minimum drive recommended, FW800 is better, eSATA better yet.
    Read my Blog!
  • Rip Swan
    April 3, 2009 at 2:12 am
    So am i just kinda screwed then? cause this is the only hard drive i’ve got at my disposal.
    And it’s weird cause i haven’t had any problems with it before. Maybe 4000% is just too much…
  • Steve Eisen
    April 3, 2009 at 3:02 am
    You are not screwed. Hard drives are very inexpensive these days.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • John Pale
    April 3, 2009 at 3:28 am
    [Rip Swan] “but when I bring their speeds up to around 2,000 – 5,000%, it won’t play the whole clip (which is now about 3-5 seconds).”
    You did render this, right?
  • Rip Swan
    April 3, 2009 at 3:35 am
    uhh yeah. Anyone think it would help to export the one clip to quicktime then import that sepperately to the sequence?
  • Bryan Banks
    April 3, 2009 at 5:50 am
    yup, that’d work
    -Bryan
