Activity Forums Apple Final Cut Pro Legacy drop and non drop frames
  • drop and non drop frames
    Posted by Rap on February 26, 2007 at 12:15 pm
    hey guys-
    could you please explain to me what is drop frame and non drop frame?
    i am working on my first NTSC project and i guess so far everything is well, other than the fact that we got few clips of PAL and I’m really worried how they are gonna look after the conversion
    my question is
    I had my project all the time set on drop frame and i never had a problem till today, i digitized 2 tapes out of three that were shot on same day, same am same cameraman.. i had no problem digitizing the first two but when batch capturing the third tape i got he message that i am capturing non drop clip to drop clip !!!! and if i continue that may cause problem with the ins and outs or relinking master clips
    i really don’t understand that could… so how do i till if the media was shot drop or non drop ? and what if i have mixed media ?
    Steven Gonzales replied 19 years, 7 months ago 3 Members · 4 Replies
  • Steven Gonzales
    February 26, 2007 at 2:42 pm
    Drop frame and non-drop frame both have the same number of frames. No frames are “dropped”. What is “dropped” are some frame numbers.
    Think of timecode as frame addresses.
    If video ran at 30 frames per second, in an hour 60 * 60 * 30 frames would go by (108,000 frames) and the timecode at the end of that time would be 1 hour, or 01:00:00 or 3,600 complete seconds of 30 frame counting timecode.
    However, frames go by at a slightly slower rate (slower by 1 part in 1000, or 1/10th of 1 percent) of 29.97 frames per second. So in an hour of time on the wall clock, only 60 * 60 * 29.97 frames go by, or 107,892 frames. The timecode at that time would be 59:56:12 or 3596.4 complete seconds of 30 frame counting timecode.
    This is all well and good, except the clock on the wall says 1 hour, and the clock counting timecode addresses says 59min56secs12frames. If you’re running a TV station, this is confusing.
    So in order to make the timecode on the tape deck match the clock on the wall, the difference needs to be fixed, so that at 1 hour the timecode reads 1:00:00 even though the frame rate is 29.97.
    The difference between the theoretical 30 and the real 29.97 is 108 frames in an hour. To make up that difference in Drop Frame timecode, two frames of the counting (addresses) are skipped each minute on the minute. So at 00:59:29 the next frame is called 01:00:02, skipping two frames of numbering.
    This is done on every minute, except the even 10 minutes. So for 54 minutes out of the hour, two frames of counting are skipped. For 6 minutes out of the hour, no frames are skipped. 2 frames times 54 minutes is 108 frames, or the difference we needed.
    No frames were “dropped”, only some frame numbering addresses were skipped to help the clock on the wall match the clock on the video tape deck or computer.
    Drop frame and non-drop frame timecode both play the same number of frames in an hour of real time.
    The difference is that non-drop frame timecode has consecutive frame numbering addresses, and drop-frame timecode does not have consecutive frame numbering addresses, as it has dropped 108 frames of the count over the course of an hour, when it skipped 2 frames of count 54 times.
  • Rap
    February 26, 2007 at 3:10 pm
    thanks
    but then why would the FCP tell me that whn capturing non drop frame clip to drop frame there will be problem with the the ins and outs and problem relinking the master clips?
    too bad iI didn’t write down the message I hope you know what message I’m talkig about
  • Gsp
    February 26, 2007 at 3:49 pm
    I believe this question is in the wrong forum….probably should be in the FCP Basics forum
  • Steven Gonzales
    February 26, 2007 at 7:36 pm
    If you log a clip as non-drop frame, for example, and it goes from 01:00:30:00 to 01:01:00:00, and then you place a tape which is drop frame for capturing, the computer will not be able to locate to 01:01:00:00 for the end point, because that frame address doesn’t exist on the drop frame tape.
    The warning message is to let you know this might happen, and frame addresses will be recalculated when going from non drop to drop frame.
